Will I notice a difference between 3" and 4" intercooler piping?
Old Apr 1, 2009 | 07:26 PM
BigRich954RR's Avatar
Originally Posted by chuntington101
anyone got any answers/imput to this question???
All i was after was someone to give me some CFM numbers for the pipes using PV=NRT and asuming you have a maximum air speed of 250ft per second @ 20psi......(cant rember the veriables)
sorry if i didn't make that clear.
the reason i ask is i know STS guys have problems with the piping they run once they push past about 700rwhp. now if we know that a 3.0inch pipe can support say 125lbs of air per min then you know you can run a 3.0 inch pipe on a 1000bhp setup.
basically just trying to understand at what point, BHP wise, you need to run bigger piping.
Cheers
Chris.
Thats what i mean a there no standed for pipe flow in a engine to = hp. A 1 foot 3inch pipe might flow 300 lbs of air but the same 3 inch pipe that 15 feet long might only flow 150lbs. Now take the 15 foot long pipe and flow 200 degree air though it might only flow 100 lbs now
When you get into boost the cfm flow changes ever thing raw flow numbers mean alot less a 2.5 inch pipe car in FL might only make 600 hp but same car in canada on a cold day might flow enough for 800hp. The flow of the pipe stays the same but the density of the air changed
Can it be figure out YES but you need every last spec and detail. then you have to pay some one to sit there for a few hours to mock it out.
ME degree in a good college is about 65 grand
Old Apr 2, 2009 | 02:06 AM
chuntington101's Avatar
I see your points mate. i guess it is down to each application rather than what BHP you plan on running.
Just wondered if it was like exhaust though where they say oh for xxxbhp you need a 'something' inch exhaust. if thats not the case for the intake then no worries.
Chris.
Old Apr 2, 2009 | 02:09 AM
Originally Posted by Tricked-Out-Toy
Where did the 250fpm come from? At 250fpm a 3" is only 12.27cfm and a 4" is only 21.81cfm??
Feet per second mate!
i cant rember the guys but it was on one of longrange4u's threads. He was talking about how restrictive the stock STS pipe work was on the cole side. Someone said you want to keep air speed below 250 feet per second as thats when you start to encounter problems. I think Zombie for longrange did some calcs and figured they where nearly in the 400 feet per second range!!!
Chris.
Old Apr 2, 2009 | 11:49 AM
Tricked-Out-Toy's Avatar
Chris.
Reading comp owns me.... Thats a big difference lol. 250fps is 15000fpm. At 15K fpm your looking at 736.3cfm through a 3" pipe and through a 4" your looking at 1308.9cfm.
At 400fps your looking at 1178cfm through a 3" and a 4" is at 2094cfm.
If your feeding lets say a 408 your looking at needing about 1500cfm at atmospheric pressure spinning to 6800rpms. So on a 3" setup your going to have to push past 400fps to about 534fps.... Thats moving some friggin air but thats only if you can overcome the headloss though the 3" pipe.. Your looking at about 660in.wc/100' head loss
Old Apr 3, 2009 | 01:53 AM
Cheers, what are the presure for the above???
Old Jun 17, 2009 | 07:48 PM
Taubr Unit's Avatar
any updates on this? Im tore between 3'' and 4'' myself.
Old May 9, 2012 | 07:30 AM
Punisher_ws7's Avatar
i have 3 " now... 402ci l92 heads and A F1A with 3.7 pulley..
i have 25 psi on the hot side of my CXRacing intercooler and only 15psi at the engine... thats a 10 psi drop... ive got to do something..
my d1sc with 3.4 pulley made 13psi and 676rwhp through a 4l80e
my F1A with 3.7 pulley made 15 psi and 700rwhp through a 4l80e
Both pulleyed to the max.... im thinking bout my options now
Old May 9, 2012 | 11:45 AM
Broke EF's Avatar
We changed from 3.5" to 4", but haven't run the car yet. The piping setup on the car is 3" out of the turbo (76mm turbo), transition to 3.5", silicone adapter from 3.5" to 4", intercooler is 4" in and out to make it "future proof", 4" from the intercooler to the throttle body where there is a 4" to 4.5" silicone adapter.
Obviously we don't for see any downside to the layout, and the main reason for it is for a future larger turbo. If the turbo is 3.5" or 4" outlet, all of the piping (save for a small section) is already in place. It also looks better with the massive throttle body to have a pipe that is close to the same size. Working with 4" tube is a pain in the *** though, so much more welding!
Sean
Old May 9, 2012 | 12:08 PM
s57_s2k's Avatar
Originally Posted by stangeater01
heres a question for a noob if your throttle body is 90mm which is 3.5" why would you go piping larger than throttle body and why would you go bigger piping then the intercooler inlet and outlet?
theoretically to reduce pressure drop that comes from the pipe restriction. even if your TB is smaller. but the question is how much ? is it worth it ? .
Old May 10, 2012 | 03:27 PM
fastsspr's Avatar
Question
Originally Posted by Jimmy P
I would go with 4" piping. It shouldn't hurt anything. I just dont like using too many reducer couplers. My chassis guy made my entire intercooler setup in 4" piping. It might be a little overkill for my baby F1C blower, but if I ever upgrade to a F2 it will be perfect.
What intercooler is that one? Were you find it?
Old May 10, 2012 | 04:30 PM
NoGo's Avatar
I've debated doing this on my car.
The air has to really bake through a 3" section at 700 HP. Probably between 400 and 600 fps.
We've got some fancy modeling software at work and I was showing at those flow rates, you can induce a between 1 and 2 psi pressure drop over just a few feet of piping. It really boils down to your bends and piping length. Its modeling software so take it or leave it.
I think going to 4" you may be able to get a little more out of a specific turbo, but I don't think it is going to make much of a difference - so you add a smidge more in back-pressure - no biggie.
I think this is a better mod for the S/C guys with a fixed impeller speed or folks expecting to move much higher in HP.
Old May 11, 2012 | 07:02 AM
  #32
NoGo, some intresting maths here on dynamic flow rates and what size piping is needed to minimise restriction.... (half way down post by user Max_Torque).
http://www.pistonheads.com/gassing/t...tion&mid=36792
Chris.
Old May 11, 2012 | 09:29 AM
  #33
MIGHTYMOUSE's Avatar
mines still 3" and stock throttle body is smaller than that so the pipe doesnt really matter.
Old May 11, 2012 | 10:31 AM
  #34
NoGo's Avatar
Thanks for the link. I do it a little differently - the easier way.
Also, the way he does it isn't applicable if you have a turbo or supercharger on the car.
To figure out charge speed:
Engine Flow Naturally Aspirated = (((Cu In/1728) * RPM) / 2) * Volumetric Efficiency
so for my engine...
Engine Flow Naturally Aspirated = (((383 / 1728) * 6400) / 2) * 0.85
Engine Flow Naturally Aspirated = 602 CFM
Engine Flow Boosted = (Boost+14.67)/14.67 * Engine Flow Naturally Aspirated
so for my engine...
Engine Flow Boosted = (17 psi + 14.67 psi)/14.67 * 602 CFM
Engine Flow Boosted = 1299 CFM....about out of room with the D1
To figure pipe velocity:
Pipe Velocity = (Engine Flow Boosted / ((((Pipe Diameter^2)/4 * 3.14))/144))/60
so for my engine....
Pipe Velocity = (1299 CFM / ((((3in ^2)/4 * 3.14))/144)/60
Pipe Velocity = 441 fps
In an ideal world I would try and keep pipe velocities to no more than 100 fps. Above 100 fps you start to get out of the valley of the curve and head up the non-linear portion for pressure drop. However, I don't think this is very realistic in our world of 600+ HP.
I think going through the above math and adjusting your inlet piping accordingly makes sense for N/A application. I don't think it is realistic for most supercharger applications and I'm sure it is just splitting hairs with a turbo - so you spin your turbo a smidge faster....no biggie.
JMO.
Old May 12, 2012 | 09:59 AM
  #35
Old Geezer's Avatar
This thread....
http://speedtalk.com/forum/viewtopic...r+pipe#p347197
Old May 12, 2012 | 12:48 PM
  #36
Fb0dy0nly's Avatar
Originally Posted by Old Geezer
have to register and sign up just to read....
Old May 12, 2012 | 08:17 PM
  #37
SS4Matt's Avatar
I have nothing to add to this as far as insight, but the 4" sure looks cool!
I have 3.5" from my turbo to the IC, and a 4" from the IC to the Throttle body.
edit, the 4" matches right up and I have a stock TB. I have a 4" coupler that fits perfect.
couple old pics from fabbing it and stuff
Old May 12, 2012 | 11:11 PM
  #38
CAMSTER's Avatar
Default Bracket..
Above inter cooler bracket, best I've seen...
This is the answer to the much debated question, as to, whats the rite diameter for the charge pipe, The same diameter of the throttle body, is the correct answer.
Old May 12, 2012 | 11:40 PM
  #39
SS4Matt's Avatar
thanks! a few chassis tabs, about 20 feet of 1/4" chromoly round bar and a few evenings and a couple beers. The radiator is mounted and floating in the core support by that as well as the trans cooler.
Old May 12, 2012 | 11:59 PM
  #40
tt383lt1's Avatar
i have two 2.5" piping coming from the turbos to my two intercoolers then two 3" pipes merged into one pipe into the throttle body. i would think the bigger the pipe the more leg you would have.
