Will I notice a difference between 3" and 4" intercooler piping?
Old May 13, 2012 | 04:55 AM
  #41
crashly's Avatar
Originally Posted by chuntington101
at say 20psi, how much air can you psuh through a 3.0, 3.5, 4.0 inch pipe??
Cheers
Chris.
Outlet on these TC turbonetics is 2 inch id
Hp 76 billet wheel is rated at 1000+ ...same I'd outlet
Old May 13, 2012 | 02:41 PM
  #42
slow67's Avatar
Gingervitis Addict
Originally Posted by NoGo
Thanks for the link. I do it a little differently - the easier way.
Also, the way he does it isn't applicable if you have a turbo or supercharger on the car.
To figure out charge speed:
Engine Flow Naturally Aspirated = (((Cu In/1728) * RPM) / 2) * Volumetric Efficiency
so for my engine...
Engine Flow Naturally Aspirated = (((383 / 1728) * 6400) / 2) * 0.85
Engine Flow Naturally Aspirated = 602 CFM
Engine Flow Boosted = (Boost+14.67)/14.67 * Engine Flow Naturally Aspirated
so for my engine...
Engine Flow Boosted = (17 psi + 14.67 psi)/14.67 * 602 CFM
Engine Flow Boosted = 1299 CFM....about out of room with the D1
To figure pipe velocity:
Pipe Velocity = (Engine Flow Boosted / ((((Pipe Diameter^2)/4 * 3.14))/144))/60
so for my engine....
Pipe Velocity = (1299 CFM / ((((3in ^2)/4 * 3.14))/144)/60
Pipe Velocity = 441 fps
In an ideal world I would try and keep pipe velocities to no more than 100 fps. Above 100 fps you start to get out of the valley of the curve and head up the non-linear portion for pressure drop. However, I don't think this is very realistic in our world of 600+ HP.
I think going through the above math and adjusting your inlet piping accordingly makes sense for N/A application. I don't think it is realistic for most supercharger applications and I'm sure it is just splitting hairs with a turbo - so you spin your turbo a smidge faster....no biggie.
JMO.
Your looking at it wrong, your engine still only takes in roughly 602 cfm boosted....the 1299 cfm is at the inlet of the D1, after the D1 it is only what your engine can ingest (you calculated at 602 cfm) only more dense.
Old May 13, 2012 | 06:23 PM
  #43
Phil99vette's Avatar
7 Second Club
I would run the 3" and transition to 4" at the throttlebody. There is no need for 4" piping on a car that makes 700hp. You will not make more power, you will not make boost faster. On a turbo car, its all about air speed and efficiency. 4" is way to big on that combo. If it were my car, it would have 1 5/8" headers, 2 1/8" crossover, 4-4.5" downpipe, 3" IC pipes
Old May 13, 2012 | 10:11 PM
  #44
NoGo's Avatar
Your right. I did do that wrong for between the supercharger and engine. Thanks for the correction.
So it would be 200ish fps not 400ish.
Old May 14, 2012 | 07:03 AM
  #45
chuntington101's Avatar
1000+ on what engine and at what boost presure?
Small engine (say 2.0ltr 4 pot) and LOTS of boost the turbo might well flow enough air to meet those numbers, but on a 572 BBC they might strugle!
Chris.
Old May 14, 2012 | 07:25 AM
  #46
Old Geezer's Avatar
Default Yep...
Originally Posted by Fb0dy0nly
have to register and sign up just to read....
I guess it's about the effort required to obtain the info....
Old Jun 1, 2022 | 10:11 AM
  #47
Mullinswing's Avatar
Default Intercooler piping size
If a 75mm throttle body is used with 3" intercooler plumbing vs upping the throttle body size and piping. Would there be any advantage to this. My concern is a larger pipe increases overall volume between intercooler to tb and may take longer for turbo to compress that air space vs the smaller setup. Any thoughts!
