How do you cut the front of your bumper for your intercooler
Old Mar 28, 2009 | 11:48 AM
adam120674's Avatar
Question How do you cut the front of your bumper for your intercooler
How do you cut the front of your bumper , behind the gill, for your intercooler. I have seen this done, but do not see how to do it clean. Don't know were to start with the shape of the front end (it kind of curves back) and the actual bumper behind the foam (don't want to commise my car structure). If someone has done this mod, could you please explain to me how you did it and picturs if you have them, Thanks. Just don't want to start cutting and end up with an ugly hole in the front end of my car.
Old Mar 28, 2009 | 12:24 PM
LS1Silverado05's Avatar
Just start searching...there are lots of pics to look at once you dig a bit..you can do it all sorts of ways..
Old Mar 28, 2009 | 12:27 PM
stevied916's Avatar
You just have to search. There are different ways you can do it as already said. Use a angle grinder with a cutoff wheel to cut the steel
Old Mar 28, 2009 | 12:49 PM
kkslds's Avatar
^^^ might help if we had a search feature worth a ****
Old Mar 28, 2009 | 12:57 PM
stevied916's Avatar
Use the "search titles only" and type in "intercooler" search in "force induction"
Just need to know how to use it
Old Mar 28, 2009 | 01:38 PM
BLNLS1/RX7's Avatar
You ned to go towww.exotic performance plus.com. They install and sell a ton of ProChargers and they will hook you up.
Old Mar 29, 2009 | 08:46 AM
AFASTYZFR1's Avatar
Dremel.........free hand
Old Dec 17, 2009 | 02:02 PM
JASON 77's Avatar
Originally Posted by afastyzfr1
dremel.........free hand
very nice!!
Old Dec 17, 2009 | 02:06 PM
XtremeDime's Avatar
I did a rough trace of the intercooler on the support then cut it off. I wanted the intercooler to slide up into the top of the support. I ended up cutting little slits on the back side and hammering the support out a little to fit it. I also cut the foam where needed. I pretty much did this to retain my fog lights LOL
Old Dec 17, 2009 | 03:08 PM
blk00ss's Avatar
On the camaro, would t cutting ALL of the bumper in the middle cause it to sag after time?
Old Dec 17, 2009 | 03:45 PM
Rickys S/C Z28's Avatar
mine dont
Old Dec 17, 2009 | 03:55 PM
LS1BLKSS's Avatar
Banned Village Idiot
anymore on this? anyone have close up pix on how the intercooler is mounted on the frame
Old Dec 17, 2009 | 04:04 PM
XtremeDime's Avatar
I have some on my phone, my intercooler isnt mounted to the frame per se. I have holes drilled in the top of the bumper support that bolts to the IC and I have a couple brackets for the bottom that bolt to the bottom of the rad support.
Old Dec 17, 2009 | 04:41 PM
importkiller_SS's Avatar
This is the closet pic i have. i drilled two holes at the top to mount it and layed the intercooler on top of the beam to get a general shape to cut.
I havent done mine yet for the bumper... but i will be using the green painters tape to get the lines layed out how i want them and follow those lines while cutting it with a small pneumatic sawzaw. If you want to have a clean look i would go buy some nice edge trimming possibly.
Old Dec 17, 2009 | 05:06 PM
LS1BLKSS's Avatar
did you fab up that rail that bolts on to the intercooler on top? what size intercooler is that
also on the pipping thats alum? painted black?
Old Dec 17, 2009 | 05:32 PM
Tally TransAm's Avatar
heres a pic of my mount for the intercooler
in my sig you can see with the bumper cut. just started with a dremel cutoff wheel then smoothed it with a fine sanding wheel, then hand sanded and touch up paint on the spots i messed up
Old Dec 17, 2009 | 05:39 PM
XtremeDime's Avatar
Looks like the stock bumper support that was cut. Piping is probably powdercoated.
Old Dec 17, 2009 | 06:51 PM
hawk584's Avatar
cutting the bumper on what car? camaro, firebird/formula, t/a, LS1, LT1?...
Old Dec 17, 2009 | 11:05 PM
it is all part of the re-bar that it bolts onto. i didnt cut the top part of it so it can have something to mount onto.
it intercooler size is 31-12.50-3"
the piping is aluminum painted black
