differences in blow off valves
Old Apr 21, 2009 | 09:31 AM
  #41
'Trust''s Avatar
Originally Posted by Grr
Ive had my tial Q on for about 2 weeks and its awesome. I have a 6lb spring cause im too cheap to buy the 3lb, and there is no problems with it. I run about 12-13inHg at idle and it is a good halfway open. God damn, this thing is loud as hell, my GF hates it. BUT, no more pipes blowing off, very quick release on the shifts as well
So a 3lb spring will let my TiAl 50mm stay a little open at idle but still stay shut under WOT ant 16psi?
Old Apr 21, 2009 | 11:10 AM
  #42
Drewstein's Avatar
Yes it will.
Old Apr 21, 2009 | 11:27 AM
  #43
Grr's Avatar
Grr
I have a TiAl 50mm BOV on my car, but I'm selling it next week to be replaced by a Vortech Mondo, it's a great piece though.
At that low boost you can use the factory BPV
LOL, i just cut off my vortech Mondo and put the Tial on cause the mondo is inferior. Couple things in its design that are lacking
Old Apr 21, 2009 | 11:50 AM
  #44
TiAL's Avatar
Originally Posted by salemetro
On my latest build, I'm using Synapse BOV and Synapse wastgate. They are supposedly the "latest and greatest"....even better than Tial....but only time will tell if that's true.
straight otta' China, the comapny says they are the latest and greatest... fact is, generally they fall apart and leak
Old Apr 21, 2009 | 11:52 AM
  #45
TiAL's Avatar
just send me your spring and i'll swap it out
Old Apr 21, 2009 | 11:54 AM
  #46
TiAL's Avatar
why?
Old Apr 21, 2009 | 12:00 PM
  #47
Grr's Avatar
Grr
Ill pick up the 3lb when i swap heads this winter, gonna lose 3-4"Hg of pull so i will need it then. Cant let the car be down cause im waiting for a spring! Its too much fun!
Old Apr 21, 2009 | 01:24 PM
  #48
52172's Avatar
TS XS here no problems whatsoever going on three years havn't even had to contact customer service.
Old Apr 21, 2009 | 01:57 PM
  #49
slothy's Avatar
tial w/ 3lb spring here and love it, loud as fawk!
Old Apr 21, 2009 | 03:32 PM
  #50
'Trust''s Avatar
So the 3lb spring is fine with 16 psi max? It won't leak boost or anything under WOT? I still don't know the mechanics of how the BOV even works so pardon my ignorance.
Old Apr 21, 2009 | 03:39 PM
  #51
TiAL's Avatar
all the rating has to do with is vacuum, it will open at -6in/hg (-3psi = -6in/hg)
the bov will hold anything you throw at it
Old Apr 21, 2009 | 03:41 PM
  #52
'Trust''s Avatar
Ok cool, if you guys think it'll work thats fine. You should have an order to drop ship to Edmond, Oklahoma from Forced Performance for that 3# spring.
Old Apr 21, 2009 | 04:12 PM
  #53
TiAL's Avatar
yep, i spoke with amber about it
Old Apr 21, 2009 | 06:24 PM
  #54
BlkHwk's Avatar
I hate China ****
Old Apr 21, 2009 | 06:31 PM
  #55
BlkHwk's Avatar
So what does this mean? Does this mean it starts to open or is fully open. The spring they sent me the other day would start to open with a vacuum pump @ 6" and was fully open @ 11". Your site doesn't show the -3 spring but it does show the 11 psi spring as pink. The spring I got has pink paint on it. So I figured it was the 11 psi spring especially since it was fully open @ exactly 11" vacuum.
BTW thanks for helping clear all this up.
Edit: After rereading your post and checking your site again it must begin to open @ 6" hg. Which is what mine does. So now I'm pretty sure I have the -3 spring. I wish you would paint it a different color. LOL
Old Apr 21, 2009 | 06:44 PM
  #56
BlkHwk's Avatar
Just open it up and have a peek. That's the first thing I did when I got mine. Just be careful not to pinch the diaphram when you reassemble it. The area of the diaphram is larger than the piston. To me that says with spring assist + boost pressure in the (vacuum port side )intake side of the diaphram it cannot open under boost. The pressure holding the piston closed will always be greater than the pressure from the supercharger feeding the engine.
Old Apr 21, 2009 | 08:36 PM
  #57
turbochkn's Avatar
snapse. hands down!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 22, 2009 | 08:48 AM
  #58
TiAL's Avatar
bingo
Old Apr 22, 2009 | 11:06 AM
  #59
'Trust''s Avatar
Ahh, that makes sense, thanks for the explanation man.
