First passes with the new D1SC/347 firehwk
Old Apr 4, 2009 | 10:24 PM
kp's Avatar
kp
Default First passes with the new D1SC/347 firehwk
Weather wasnt that great, 2400' DA, but it was only 67 degrees. The DOT QTP tires I have on there are a couple years old and not the best but I was happy how it ran for th first time out with the car.
First pass was a 6.83/108 with a bad missfire (plugs were crapped up from a lot of idling the last few days), changed the plugs, ran a 6.42 and a 6.37 @ 110mph. Leaned it out a little and finally got the shiftlight set right and ran a 6.29 @ 111.4 with a pretty crappy 1.420 60 foot, figured that was enough for the day. Need to put it in the air and make sure I didnt forget to tighten anything up, change the oil etc. I'm on a 10 minute hacked MAF tune as well so switching to a 2 bar SD should help out some, hard to get the fueling consistent on the PE table.
With some slicks on the car and a 1.35 or so 60 foot it should run in the 6 teens (9.50s 1/4), 6 ohs (9.30-9.40s) in good weather and thats good enough for me. Tune is super conservative and I was using 50/50 93 pump and 104 unleaded, 60lb injectors are about 96% so I cant go much further unless I step up the injectors anyhow. Thats also through a Y-pipe and single 3" muffler, I'm purposely choking the exhaust to keep me from going too far lol.
few passes from today:
http://videos.streetfire.net/video/4...-TN_644603.htm
Old Apr 4, 2009 | 10:29 PM
T/A KID's Avatar
Want to be the first to say sweet.
hope my car runs similiar
How hard are you spinning the blower at the moment?
Old Apr 4, 2009 | 10:33 PM
kp's Avatar
kp
Its 7.25/3.7 pulleys, at 6800rpm thats around 55K impeller, max is 62K so it has a bit to go.
Old Apr 4, 2009 | 10:41 PM
T/A KID's Avatar
Awesome
So with maxing the blower out and with a better tune you'll have another 5 second D1SC LS1 car, lol.
What heads you running this time around?
Old Apr 4, 2009 | 10:47 PM
kp's Avatar
kp
Awesome
I'd have to lose a little more weight, go to some 75-83lb injectors and change the exhaust to get in the 5s safely/consistently. I'm happy the way it is, I just need to get the 60' down a little. Thats 50/50 tires/tuning right now.
I have AFR 225s on it.
Old Apr 4, 2009 | 11:41 PM
conan's Avatar
On the first passes. What exhaust set up are you going to switch too?
Old Apr 5, 2009 | 12:15 AM
kp's Avatar
kp
I'm going to leave it for now, if anything I'll put a flowmaster 3" to 4" merge and run a 4" muffler, that was good enough for 8s on my other car.
Old Apr 5, 2009 | 12:19 AM
'Trust''s Avatar
Nice man! What did the car end up weighing and where is it at boost wise?
Old Apr 5, 2009 | 12:21 AM
conan's Avatar
Cool. Good luck with the rest of your fine tuning.
Old Apr 5, 2009 | 12:43 AM
Cmarsh's Avatar
Nice runs! But I have to ask...why did you put all the effort into building a car, then selling it, then turning around and building an almost identical car? Just curious
Old Apr 5, 2009 | 01:17 AM
CalSpeedPerformance's Avatar
The other car did a really big wheelstand and came down and did some serious damaged to the chassis and he decided to not fix it
Old Apr 5, 2009 | 02:00 AM
kp's Avatar
kp
Said 3560 with me in it at a truck stop scale which seems a little heavy, I'll have to wait to I get a track with a good sale and see for sure. 13.5-14psi at peak is what I seen on the logs.
I raced the old TA for 3.5 years and I got my money's worth out of that car, I had nothing against it, was just sick of looking at it. I didnt put that much effort into either of them really and the TA pretty much paid for this one.
Sometimes starting with a clean slate isnt a bad thing, the two cars really arent identical, lot of things I dd different on this one to make it easier to work on and more reliable.
Old Apr 5, 2009 | 02:04 AM
kp's Avatar
kp
It didnt hurt the chassis on the other car, it broke the oil pan/engine block, bent up some intercooler pipes and the headers. The old TA is getting a BBC and will be an 8.50 index car in Wisconsin.
Old Apr 5, 2009 | 05:44 AM
EPP's Avatar
EPP
Nice 1st time out Kevin! Bob
Old Apr 5, 2009 | 05:50 AM
VINCE's Avatar
Shorty Director
I second that!!
Old Apr 5, 2009 | 08:00 AM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Nice job KP! I like the blue better than black anyway.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Apr 5, 2009 | 09:24 AM
00SS4780's Avatar
Congrats and awsome as usual!
Old Apr 5, 2009 | 09:40 AM
kp's Avatar
kp
Me too, its a nice color, especially at night.
Old Apr 5, 2009 | 10:32 AM
'Trust''s Avatar
Man my pig needs to lose some weight. Good luck with it man, hopefully I'll get some numbers out of mine this weekend.
Old Apr 5, 2009 | 11:03 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Awesome no doubt for the first time out KP! You have proven time and time again that the KISS method really does work
