STS PPL Only! Turbo upgrade advice
Old Apr 8, 2009 | 09:55 AM
omore001's Avatar
Default STS PPL Only! Turbo upgrade advice
Hey folks, I'm getting ready to drop in a new forged 370 shortblock in my '98 T/A, it already has a complete STS kit +Intercooler and meth. It is 4K stalled auto, currently has a T4 Garret .67 turbo with .81 A/R. I am looking for advice on whether to try and max this unit out, or pick up a larger turbo that it capable of reaching my goals (750-900hp). The larger units I have been looking at are the T-76 and T-78 units.
Can anyone who has experience in upgrading the turbo(s) on their STS kits provide in-depth details as to all that needs to be done in order to successfuly install a larger turbo?
I would prefer to stay with the T4 and not have to alter my current piping. Thanks
don't know if this pic helps...
Old Apr 8, 2009 | 01:01 PM
omore001's Avatar
Zombie? Ninetres? Dr.Turbo? Anyone at all?
Old Apr 8, 2009 | 01:16 PM
Silver_TransAm's Avatar
You might want to go with a t78. I have a t76 that I would like to see 800whp out of with a built moter later on. I think the 78 would be better sized though an even bigger one might be needed.
All I did is run a new pipe under the axle with a new coupler on the outlet and intake side of the compressor. I added a hanger to since it starts to sag over time.
Here is how mine is setup.
Old Apr 8, 2009 | 01:35 PM
DrTurbo's Avatar
LS1TECH Sponsor
TC76 will do the job for sure.....easy swap as well. Let us know...
Old Apr 8, 2009 | 01:40 PM
omore001's Avatar
Thanks for your input Silver Transam, "All I did is run a new pipe under the axle with a new coupler on the outlet and intake side of the compressor."
That helped the most, as I was unsure of what changes needed to be made in order to run the t76 or t78.
If anyone else has some information on upgrading the turbo on an STS turbo kit, please chime in, thanks.
Old Apr 8, 2009 | 03:22 PM
ScorpionT's Avatar
The change is pretty simple, like Silver said. As long as you get a T4 turbo with the same outlet flange, they will bolt up right. If the compressor housings is different, do like silver said and replace the compressor inlet/outlet couplers.
Old Apr 8, 2009 | 03:50 PM
omore001's Avatar
Thanks ScorpionT, I'm definately sticking to T4 for simplicities sake, it hardly sounds complicated anymore. Wish me luck on the t76 or t78, whatever I can get my hands on first.
Old Apr 8, 2009 | 03:52 PM
DrTurbo's Avatar
LS1TECH Sponsor
The TC's are easy to swap in...depends though if you have the 3" inlet cover or 4" inlet cover. If you have the 4" inlet cover their is NOTHING required. Straight bolt in and go hunting!!! We sell alot of the TC's to the rear mount guys...they love them.
Old Apr 8, 2009 | 06:31 PM
He's right I love the tc turbonectics turbos .
Old Apr 8, 2009 | 06:57 PM
1320's Avatar
I know zombie's isnt an sts......Im pretty sure Ninetres isnt and I dont think Dr.turbo even has a rear mount? So unless someone wants information regarding rear mounts.....the topic clearly states, sts ppl only, so Ill have to stay out of it.
Old Apr 8, 2009 | 08:53 PM
ModularTurbo's Avatar
How's she holding up bro? Did you get those rails I sent.
Old Apr 8, 2009 | 09:03 PM
About to crank her up once I get these 60lb injectors in there. I got'em.
Hows the turbo kit coming along.
Sorry .
Old Apr 9, 2009 | 12:04 AM
OUTLAWZ RACING's Avatar
I have a gts 76 on mine from forceinductions and gettin ready to buy a tc78 once my other set up is done. Im not looking for bigger dyno numbers just lower boost levels and 200 mph lol!
Old Apr 9, 2009 | 06:31 AM
omore001's Avatar
Yeah, I meant to say rearmount turbo not STS, I am very much aware that Zombie and Ninetres have almost nothing from STS in their kits, and that all of their components are custom. I also know that you did Zombie's setup and a few others. I also mentioned DrTurbo because I know for a fact he is very knowledgable when it comes to turbocharging, be it front mount, rear mount, or STS. If you want to stay out of the thread because you feel the that the topic does not apply to you, by all means do so. It was not my intention to shut the door on all rearmount set-up guys, just because "STS" is on the topic.
