ATI Procharger Cam selection
Old Apr 8, 2009 | 11:29 PM
jjnitrox's Avatar
Question ATI Procharger Cam selection
Hi:
I need help this is driving me crazy. I have a 2000 c5 vette with stock short block(346ci). The mods I made are:Lts(1 3/4 primaries) with 3" piping and magnaflow cat back system(modified to 3"), port and polished stock throttle body,modified mass air flow and 160 thermostat. It is a six speed and a 3.42 diff.I will be installing a stage II ATI procharger supercharger kit(PSC-1). This vette will be for street performance and ocasionally taken to the track. here is the question What cam so I install? I was checking a comp cams 224-230 @.50 with 581 -588 lift and a 114 LSA also was looking at Epp blower cam 232-240 @ .50 with a 595-608 and a LSA 115. Very concern of tire spinning since is for street performance. And very concern about CLA I have no Idea of either 108 o 110 or any other. Any suggestions?, Any other cams?
Thanks JJ
Old Apr 9, 2009 | 04:53 AM
EPP's Avatar
EPP
Thumbs up
Originally Posted by jjnitrox
Hi:
Thanks JJ
Our blower cam http://www.exoticperformanceplus.com....html?item=679 has proven itself over and over again. We first used it in this 346 C5 Z06. http://www.exoticperformanceplus.com...Car.php?car=26 Bob
Old Apr 9, 2009 | 06:22 PM
jjnitrox's Avatar
Thanks Bob.
What about tire spinning? Any advice. Can you make a good cam package
Camshaft(your blower cam of course)
Valve springs(double, with no modification to the stock heads)
Titanuim retainers
Double roller adjustable timming chain
Chromemoly hardened pushrods(7.4)
Old Apr 9, 2009 | 08:16 PM
9t8z28's Avatar
This is a vid of one of the cars EPP built. This vid makes me wanna sell my Procharger and go with a similar setup!
http://s81.photobucket.com/albums/j2...MOV00004-1.flv
Old Apr 12, 2009 | 08:08 PM
CalSpeedPerformance's Avatar
I think the EEP blower cam is much more than you need for a stock shortblock...honestly I think its more cam than needed for anything typical 600 rwhp type procharger setup.
I would recommend a XE-R lobed 220/224, 224/230 isnt a bad choice either but if you are going to limit it to 550 rwhp or so, then even those cams are more than needed....
Just a stock LS6 cam would do the job fine actually...
Old Apr 12, 2009 | 09:38 PM
allthrotle's Avatar
Im running the comp 224/230 with .581/.588 I think I made a good choice. I put down some decent numbers with it.
Old Apr 12, 2009 | 09:46 PM
9t8z28's Avatar
What numbers?
Old Apr 13, 2009 | 04:46 AM
EPP's Avatar
EPP
Thanks Bob.
Titanuim retainers
M/T drag radials are a great way to go to control wheelspin, but if you run them all the time you won't get a lot of mileage out of them.
EPP Blower Camshaft $389.99
Patriot Gold Valvesprings with titanium retainers $255.00
Comp double roller timing chain pn#7153 $124.61
Comp 7.40 pushrods $124.00
Shipping: Free
Thanks. Bob
By Brett Foote | 2026-06-04 05:00:17
