Gen TTr f-body guys come on in!
APS car here. 600rwhp at 7.5lbs of boost. Stock engine on 91 octane. Kit fit perfectly, just had to make some spacers for the swaybar. Turbos are fine and arent gonna get knocked off on speed bumps.
Thanks for clarifying as you did come across hostile
The only thing some might consider "an issue" would be ground clearance, otherwise no, I havent had any issues. However, turbo's blowing/leaking and/or piping sucking shut, is not something i would consider a normal issue.But to each is own.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
