bs3 fuel prob with log pics
Old Apr 26, 2009 | 08:52 PM
crf538's Avatar
Default bs3 fuel prob with log pics
heres the problem,
i took these three logs yesterday and got three way diffrent results
yellow line is command afr and its 11.2:1
from left to right,
normal, except for the weird lean spike to 14:1 that lasts for like 3 ms
middle. this is where it got crazy, i wasnt looking at the wideband cause i was watching other things and the tune had been a little fat, so i thought i was fine. The leanest it reads is 15.7:1 under boost..but the car was clear and pulling just like normal
right. this was the last one i took, it seems to lean out in the upper rpm range for both gears.
i figure you can get the picture from the jpg, let me know if it will help and ill post the log files
the motor never skipped a beat and the tune was never changed at all, i tested my fuel pump for and hour and it was fine, regulator seems to be working fine
any ideas? bad sensor, fuel pump going, regulator hanging up?
its a bosch 420 in the tank with a magnafuel regulator, 76mm turbo and bone stock longblock, boost is only at 5 psi, 60 lb injectors 45 psi base pressure
Old Apr 26, 2009 | 09:04 PM
qqwqeqwrqwqtq's Avatar
Route your wideband wiring as far away from the coils and ignition wires as possible.
I have seen non-resistor plugs interfere with the BS3 wideband as well making it show randomly maxed out lean.
Old Apr 26, 2009 | 09:21 PM
crf538's Avatar
ive got ngl tr6's, they are resistor type right?
ill check about that wire, thanks for the tip
Old Apr 27, 2009 | 05:23 PM
crf538's Avatar
so the sensor wire was pulled right over the #8 coil, hopefully that helps. im gonna sort out a few other things before i try it
Old Jun 30, 2009 | 03:57 PM
crf538's Avatar
i just stumbled across this post, i had forgotten about it. turns out the fuel pump wasnt big enough so it was leaning out very quickly
