Guys with FI cars!
Take a good look at the placement of the AC condensor and the radiator. You will see the fresh air path for the air to cool the radiator goes through the AC condensor first. This fact explains why your radiator isn't efficient and can't transfer enough of the engine heat when the AC is on because all fresh air goes through the AC condensor first and is heated. The heated air then passes through the radiator. As a result the coolant in the radiator get hotter and hotter and hotter.
https://ls1tech.com/forums/forced-in...-question.html
Add redline water wetter, have funs turn on low like 170 or have manual fan switch to bring them on all the time in really hot weather. Buy a bigger rad, higher flow water pump.
My car with similar setup is doing pretty good in 80s to 90s we are having lately. I don't always run my air though and have redline water wetter and fans are coming on at pretty low temps, 160 stat also. So far no problems at all city or highway.And in pretty heavy traffic. If it hits 100 or so and have problems will look at upgrading rad and water pump. Keeping it out of boost usually helps too.
Anyway, taking the lazy way out I added Red Line Water Wetter. It seemed to have no effect. I then added Hyper Lube brand stuff from off the shelf at Pep Boys
I just read some tests comparing water wetter and hyperlube and there is less than 5 degrees difference between the two with hyperlube getting the lowest temp (202 to 206) when mixed with 100 percent distilled water.
The next best ratio is 75 percent distilled water and 25 percent anti-freeze + the additive (water wetter or hyperlube).
Just pouring in a bottle or two of either to a 50/50 mix will only reduce temps 6-8 degrees.
I am going to try HyperLube but this time will mix 100 percent water rather than 75 percent water and 25 percent anti-freeze . Unless you drain the block it is very hard to get all of the anti-freeze coolant mix out by just draining the radiator.
If you run 100 percent water you will have to add anti-freeze in the winter for climates that get below 32 degrees unless you store the car in a heated garage.
I had put in the Red Line the summer previous to that one, so I had tested it out fairly well and for whatever reason it failed to alleviate the problem of coolant temp climbing during A/C use.
Was you car a pre-1998 or 1998-02?
Hope this helps some
PS,I forgot ,,,Make sure your high fans are comeing on when you turn on the AC too. Could be a high low fan relay thats bad!
