New turbo setup losing boost...??????
Old May 2, 2009 | 09:57 PM
2002RamAir's Avatar
Default New turbo setup bleeding boost...??????
I have a kentucky turbo t78 setup and my car is not holding boost. Had the car dyno tuned and it was losing load on the dyno... Had a leaky rear main and factory clutch so figured that was the issue... clutch slip. Well just installed a monster lvl4 and went out for a test run and still have the same problem. The car comes into boost at about 3k rpm hits about 5psi and starts dropping down to about 3psi by redline. This car is not even putting down enough to spin the tires in first gear.. Does anyone have any idea what this could be?
Old May 2, 2009 | 10:08 PM
topend's Avatar
check your coldside plumbing,vacuum hoses intake gasket ,for leaks . if no leaks were found than i would check the wastegate.
Old May 2, 2009 | 10:11 PM
98Z28CobraKiller's Avatar
Restricted User
What is it supposed to be at?
Old May 2, 2009 | 10:28 PM
2002RamAir's Avatar
The cold side has been gone over a couple times. The vacuume hoses have been checked... The wastegate does not appear to be leaking no exhaust around flanges... The only thing that could be the problem is the intake gaskets but have no idea how I would check those?
Its a turbosmart gate with a 7psi spring being controlled by the turbo.
Old May 2, 2009 | 10:39 PM
Restricted User
Is it running ok other than the boost issue? Same in every gear?
Old May 2, 2009 | 11:44 PM
2002RamAir's Avatar
Yea it seems to be running just fine. It looked great on the dyno other than losing load making the boost bleed.
Old May 3, 2009 | 08:51 AM
2002RamAir's Avatar
Would my boost bleeding off possiably be because of where the wastegate is referenced from? If I moved it from off the turbo to the intake would that maybe fix my prob?
Old May 3, 2009 | 05:50 PM
2002RamAir's Avatar
Does anyone have any other ideas of what could be going on? This is driving me nuts and i need to figure it out...
Old May 3, 2009 | 06:59 PM
TURBHOE's Avatar
12 Second Truck Club
i would reference the manifold vise the turbo itself. i have a hobbs switch on my turbo to run my second fuel pump. and depending on throttle % i can make it turn the pump on at different manifold boost levels.
Old May 3, 2009 | 07:17 PM
98Camarod's Avatar
Are you using the right port on the gate? I'm running off of my gate and see 7-8lbs and have mine referenced off of the manifold.
Old May 4, 2009 | 01:58 PM
2002RamAir's Avatar
Just switched the gate to be controlled by the manifold and now im seeing a constant 6psi in 85degree weather.. Is this good? Its a 7psi spring...
Old May 4, 2009 | 03:32 PM
98Camarod's Avatar
You're talking about at WOT correct? It should go slightly above and then the wastegate should open to lower the psi
Old May 4, 2009 | 06:24 PM
2002RamAir's Avatar
At WOT im only hitting 6 psi max... I dunno the tune is off now tho and have to find a new tuner... mine is moving and does not have time to finish my tune.....
Old May 4, 2009 | 06:27 PM
TURBHOE's Avatar
the waste gates not always going to be dead accurate. i have a 7psi spring and run 10psi. is it a huge gate? as long as its steady I'd call it good. if you want more use a controller.
Old May 4, 2009 | 06:55 PM
2002RamAir's Avatar
The gate is a turbosmart 38. It seems to be steady from looking at the boost guage. I guess ill know more when I find another tuner to finish it...
Old May 4, 2009 | 07:30 PM
98Camarod's Avatar
Are you logging it and thats how you know how much boost you are running or are you just guessing? I have a turbosmart 38mm ultra gate also with the 7lb spring, thats why I ask
Old May 5, 2009 | 10:51 AM
2002RamAir's Avatar
just guessing based on boost guage.. I have no way to log it..
Old May 5, 2009 | 11:31 AM
DrTurbo's Avatar
LS1TECH Sponsor
Use a different reference......off the intake instead of the turbo scroll.
Old May 5, 2009 | 02:03 PM
98Camarod's Avatar
He changed it to after the throttle body and sees 6 psi
Old May 5, 2009 | 03:55 PM
2002RamAir's Avatar
Yeah im using the port on the intake where the pcv was hooked up for the reference for wastegate and using the brake booster hose for the reference for my boost guage...
