air to water intercooler
Old May 6, 2009 | 12:28 AM
mightybird's Avatar
Default air to water intercooler
who uses one i would like to hear some of the pro's and cons of this set up i really dont want to remove my plate cover for a air to air set up some of the kits i have looked at seem to be pretty salty but i know there great for track use and like the idea of adding ice water at the track i pretty much have all the peaces to my system and the intercooler is the main part im fighting with.
im going to wait till this fall to install the kit till i figure out a total plan of action untill then i will be going all motor and spraying the car.
Old May 6, 2009 | 06:32 AM
BLOWNBLUEZ06's Avatar
if you do any street driving, you'll heat soak that thing and it will be less efficient. Great at the track. Bad for weekend warriors. I prefer a good meth kit in addition to my A2A intercooler. It brings my IAT's below ambient.
Old May 6, 2009 | 10:08 AM
99Ls1fever's Avatar
If you are worried about that, Put a 50 shot on there and it is cheaper than methanol injection and you will get the same benefit and maybe more power. You already have the nitrous kit so you dont have to buy that. I am running a g trim with a/w and a nitrous plate spraying a 100 shot and have never had a single problem.... Name:  coffee.gif
Old May 6, 2009 | 10:14 AM
HUNTER02SS's Avatar
Try telling this to Mightmouse. There is such a thing called
a "heat exchanger" and they work very well. A A/W intercooler will out perform a A/A when it is properly setup. Daily driving or track duty.
Methanol is good for when you don't have a properly sized intercooler for your setup!
Old May 6, 2009 | 09:25 PM
crf538's Avatar
i dont even have a heat exchanger on mine and its fine, im sure a heat exchanger would help but even without it my iat's are good. i def vote for air to water
Old May 7, 2009 | 06:26 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I am sure you do have one. If you did not, your IATs would be in the 200s in no time.
Old May 7, 2009 | 07:37 AM
topend's Avatar
i run a2a on the street and have zero problems.
Old May 7, 2009 | 11:21 AM
99Ls1fever's Avatar
Both of your signature links no longer work. Where in colorado are you from?
Old May 8, 2009 | 09:22 PM
crf538's Avatar
are you honestly telling me about the car that i built, maybe this was a misunderstanding...i have an intercooler, but my system consists of a 2 gallon resiviour, a pump, and the intercooler...there is no heat exchanger to cool the water back down except the intercooler when im not in boost. it hasnt been a problem so far.
Old May 9, 2009 | 07:51 AM
2001WS6Vert's Avatar
I just went back to air/water. We were base tuning the car before we had the water pump system done (dry intercooler). The IAT's would be 140 during an interstate cruise.
Old May 11, 2009 | 03:00 PM
DeltaT's Avatar
Me too. I can't see how an A2W wouldn't get progressively warmer over the course of the day and a few hot runs.
Jim
Old May 11, 2009 | 10:20 PM
MIGHTYMOUSE's Avatar
this is incorrect; i not only do 'any' street driving, i do a ****-ton and it just does not happen.. at least not on a turbo car (shameless plug)
i actually stole the heat exchanger off my intercooler and hooked it to my transmission last season! I didnt want the heat exchanger WARMING UP my ice water while i was at the track (go figure huh?) also note that methanol is also good for fuel
this is incorrect. for example my 13 hour dive to memphis tn. from va had me arrive with roughly ambient water in my intercooler. you only need to remove heat as fast as you are adding it.. and when just cruising with a giant aluminum box hanging from the car in the breeze, it gets the job done
def. should have had water in it, it works much better that way
Jim
i can do a single 3 gear pull, or a few individual gear pulls on the road before the iat's go up (just ambient water and spraying meth) by that time normally whoever was trying to race me has gotten the idea.
thats just how it is.. in fact during the winter, i remove my pump, tank, and lines from the system completely in about 10 minutes because it is just totally unnecessary
vid of tank running
http://videos.streetfire.net/video/i...ank_186951.htm
Old May 12, 2009 | 05:41 AM
usd2sing's Avatar
i followed MM's lead.
ride is a DD and i see nothing over ambient, even after sitting in traffic during the daily 90min ride home from work. (but i do have a pusher fan on the heat exchanger)
6gal tank
http://smg.photobucket.com/albums/v7...t=100_1354.flv
Old May 12, 2009 | 06:39 AM
I was just throwing that out for reference. Didn't lay into it and most regular cars go well into the 100+ IAT's during regular driving, doesn't hurt anything. I will say this though air/water systems definitely can get overwhelmed after a few blast (i.e. SCCA, roadracing, playing cat & mouse). I don't think you could build one that could cool the water back down quickly enough. So if you have made several blast in a row you had better be aware that you might be into the danger zone. If you like to be able to go WOT over and over with no worries air/air would be what you want. I like air/water on my car because I have less pressure drop + my car runs like it's a cool day during the heat of summer (iced down) + it gives me something to do at the track between runs and looks more trick. I'll post some pics of my setup when I'm running again (doing 4L80e changeover). It has a 5 gal. tank in the trunk + a 12 x 24" heat exchanger with dual fans up front that you see through the front plate like the FMIC guys.
Old May 12, 2009 | 01:26 PM
Denali08's Avatar
vid of tank running
So, you're saying you ran the A/W IC dry in winter and yet it's still doing good! What temp and what boost?
Old May 12, 2009 | 02:50 PM
crf538's Avatar
if i remember right mightymouse leaves the intercooler full of water and caps off the lines going to it, so there still is water in the intercooler, its just not circulating.
seeing that is why i didnt put a heat exchanger on mine
Old May 12, 2009 | 07:34 PM
in the winter i fill it up with antifreeze and cap off.. yep
dang nice tank, glow in the dark too?
a/w is totally the wrong intercoler if you are making laps i agree, i am saying that a continuous beating does not happen on any outings for me.. its here or there type of thing
Old May 12, 2009 | 08:56 PM
4SFEDZ's Avatar
what kind of core size is recommended?
Old May 18, 2009 | 03:00 PM
mmorellicamaross's Avatar
were can I get one of those 5 gallon resivors that works with a/w aftercoolers?
Old Jun 24, 2009 | 07:23 PM
twinturboz161's Avatar
any more info to add to this thread?
I am curious of cruising IAT's with a decent size exhanger, and also what kind of iat's do ya'll see with ice?
And to the posters that do street driving, how does it do for say going out on a saturday night, crusing around and occasionally getting on it, assuming you'd put a 7-10lb bag of ice in the resouvour before hand and are running a exhanger. I'm just curious to see how fast the water heats up from consistant driving if you start off with really cold water.
