Picture thread of my EZ 94mm KYTP Build!!
Old 05-21-2009, 07:01 PM
  #61
HUNTER02SS's Avatar
Originally Posted by Denali08
Do you have to take the engine out to do such paint job? Even with no headers or turbo hot/cold piping?
Did you have to remove the k-member, a-arms and rest of the parts?
The k-member and all suspension is still together. You unbolt the k-member from the frame and the tranny x-member and raise the car up and the motor stays put. It is ALOT easier to do it this way. Especially since all my parts are new, I didn't want any overspray on anything. To do a good job , this is the way to do it. Just like painting anything else on a car, you want to remove as much as possible to do a good job.
Old 05-25-2009, 10:14 AM
  #62
HUNTER02SS's Avatar
It's getting closer. I wrapped the headers this time. I will see how I like it, and if not I will get them coated. I painted the intake tube gloss black. Turned out really nice. One problem though. When the turbo kit was built it was built on the original worn out rubber motor mounts. I had a set of solid made off of a new set of of stock mounts and I lost appx. 1 in of hood clearance. Here is few more pics.
Old 05-25-2009, 10:45 AM
  #63
Coal Mining Director
onfire's Avatar
That is a killer looking turbo kit! 8's on the way.
Old 05-25-2009, 11:34 AM
  #64
7 Second Club
Phil99vette's Avatar
Nice lookin combo, sounds like bottom 8s should be pretty easy.
Old 05-26-2009, 06:33 PM
  #65
Vetal's Avatar
Hunter, how is your downpipe routed? I thought you can't fit 4" on drivers side due to steering column?
Old 05-26-2009, 10:26 PM
  #66
Josh@KY-Turbo's Avatar
Routed throught the drivers side of the Turbo K-member.
It fits. No worries there.
Old 05-27-2009, 07:58 AM
  #67
HUNTER02SS's Avatar
We used the Turbo K-member and that allows the extra room for the 4in. down pipe to fit.
Old 05-27-2009, 03:30 PM
  #68
Banned Village Idiot
LS1BLKSS's Avatar
i want one
Old 05-27-2009, 05:27 PM
  #69
_916ls1z28_'s Avatar
ballin... ! i likes
Old 06-26-2009, 04:57 PM
  #70
HUNTER02SS's Avatar
Little update. All the fuel system is done under the hood and return line is hooked up. All vacum lines hooked up, I installed the BS3 today and just have to straighten out the wires to make it look nicer. Dropping the fuel tank tommorrow to get ready for the sump and then add the 3, 044 fuel pumps.
Once that is done, I will be getting the driveshaft made on Monday, and then add some fluids and I SHOULD be done and ready to fire up. I am sure i am forgetting somthing though, but I will do a final check before we fire it up.
Old 06-26-2009, 07:09 PM
  #71
02SSLE's Avatar
Sweet looking setup.
Old 06-30-2009, 04:48 PM
  #72
HUNTER02SS's Avatar
The fuel system is done! I had a sump welded in my stock tank, with 3 -10 fittings out of the sump going into each of the 3 fuel pumps. Then I had the pumps setup just like my old car with 2 pumps connected together, but then I added a 3rd pump and connected it with a "T" fitting and a 90deg. elbow fitting. The 3rd pump actually is by itself to a point. It worked out the same as I was going to use a "Y" block but this worked out and it was easier to do.
Then it all hooks up to a -8 line to the rail, and again I am using the stock feed line as my return line to the tank. Here is some pics.
Old 06-30-2009, 06:27 PM
  #73
Black Sunshine/ 00SS's Avatar
Very nice. Subscribing.
Old 06-30-2009, 07:37 PM
  #74
Derek@BPP's Avatar
Man I thought this would be tearing up the streets by now. Give us a sound bite when you fire it up. Sweet ride even though it's a Chevy LOL
Old 06-30-2009, 08:40 PM
  #75
99Ls1fever's Avatar
Very Nice!!! What rockers are those? Jesel?
Old 06-30-2009, 10:36 PM
  #76
Ford Boys.........
Old 07-01-2009, 07:38 AM
  #77
HUNTER02SS's Avatar
The car would of been running by now, but since we bought Yamaha's new badboy waverunner, the lake just seems alot funner than working on the car in 98deg. weather. LOL!!
Yes, JEsel rockers.
Old 07-01-2009, 03:03 PM
  #78
Fireball's Avatar
did you spray your wrap? I tried the thermotec 2000F spray over my wrap and it seems like they are holding up nice so far
Old 07-01-2009, 08:03 PM
  #79
Derek@BPP's Avatar
I don't blame you. If I had one, I'd be on the lake too!
Old 07-01-2009, 08:43 PM
  #80
HUNTER02SS's Avatar
Yes, I sprayed it the Silver color. It made the headers fit extremely tight. Really no need for motor mounts. LOL!
Quick Reply: Picture thread of my EZ 94mm KYTP Build!!
