Do certain turbos make more sound then others!
Any turbo with a surge slot will make alot of noise. The Borg's make noise mostly due to all the covers they run are surge slotted. A GT42, GT45 and GT47 with surge slots make a ton of noise as well. Also depends on whether you dump to atmosphere or not with your wastegate. The gate dumping to atmosphere will drown out almost anything....
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Not on mine...WG dumped to atmosphere and all you hear is the jet fighter whistle
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
dr. turbo what would mine sound like
st80 t6 3.5 downpipe dumped WG to atmosphere, would it make more noise if i make my WG dump into the exhaust?
my setup is almost complete and i really hope i can here the turbo
Dumping back into the DP will make a nice difference in sound. You will only hear turbo....
Some things that can make sound louder...haveing metal intake pipe that is pretty much open element. Opening the exhaust cutout. My standard aps are not that loud but can hear them better as said when open cutout. Blow offs are loudest when non recirced but that is not the spooling up sounds just the steam engine venting sound or the sneeze sound.
I didn't like my too quiet recirced bosch blow offs so went with twin supersonic turbosmarts which are non recirced. Will be firing car up shortly and have a report. I think the ball bearing turbos are pretty loud too like gt35R types like have in my 97 talon and will have in my race talon.
#37
here's what a FI-x ETT turbo sounds like when I had the car on a mobile dyno:
http://home.comcast.net/~tfranklin55...dyno_small.wmv
#40
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Wow, that is diffrent.. Im in shock.. I now need one, what are you running?
http://www.forcedinductions.com/productsFI1.htm
