35th LE APS FINALLY DONE (Not tunned)
Its off of the wooden blocks wheres its been for the last year since Be Cool sent me a bum rad which destroyed my brand new Rossler stage 3 trans and all of the coolant lines
As you can see from the pics, i lowered the car over the winter with a Strano setup,Installed a new S60 rear ,Corvette brake conversion kit ,CCW 505a 18''rims and installed a new GMMG exhaust which exits threw my SLP CME. Also,i gave the under hood area a little love too LOL Im also adding a vid/sound clip of her also,i just gotta get her tunned now
Nate from nasty performance mentioned a company called QTP or something like that from New Jersey thats he said is really good at SD tunning and does all of their rides for him???Anybody hear of this place GOOD OR BAD???
Heres the vid !!http://s243.photobucket.com/albums/f...amaro%20video/
heres the pics !!http://s243.photobucket.com/albums/f...camaro%20pics/
It might not even be QTP? It was Nate from Nasty Performance that told me about this place in NJ that tunes all of their rides,,, he said there good? Was just wondering if you guys kbnow of a good SD tunner close to me ?
and thanks by the way knightmare LS1 Last edited by barnat; May 17, 2009 at 04:16 PM.
Im running a Crower (#00572 )turbo cam in my 6.0Its duration @.050 is a (I) 217 (E) 226 Lift is (I).553 (E).575 Lobe center 114 deg. I called CompCams first and was very disapointed
I am in the process of putting my Strano springs on the car. Did you go with the spacers and shorter end links for the front sway bar? I gotta get that ironed out before I put it back on the ground.
Its all goood now though.Heres some pics of the redid pipe if intrested?http://s243.photobucket.com/albums/f...%20APS%20pipe/
I just got back from taking a ride and ******* hit a piece of black top the size of a pumpkin LOL
It passed freely right under the car infront of me and i could'nt miss it
I just ordered the new B&M tranny pan from Summit about a hour ago GO FIGUIRE
Oh no! Thats happened to me before, sucks. Could of been worse.
You'll keep it around 750/800ish horsepower for a while but I bet it'll be turned up to 4 digit horsepower numbers if not within the ballpark.
I would be happy to just drive my car once this season. Can't drive it till figure out what is up with my cam sensor problem as it can't run the 120s with screwed sensor it defaults to batch fire mode and the big injectors have to be run sequential or the car floods out huge at idle. Problem is intermittent as today it went away for a bit and car ran great for 15 minutes till it started happening again. So frustrating cars can be !
I couldn't go wot last season as was on stock fuel pump with 60s. By 1000hp hope you mean mabye 800rwhp and that might even be close with 60s. I would at least go 80s high impedence if was really trying to go 800rwhp. I am shooting for 1000rwhp now but that is combination of boost and spray. And the spray don't need bigger injectors being wet type but went to 120s just in case want to run some e85 ..if we ever get it here.
And Hugger you shoudl go post on Toms thread about think your still good luck and pretty high mileage on your kit? And you are on original turbos still right??And no scavenger pump either right?
