Car just doesnt seem to be as fast as it should be...
Old May 26, 2009 | 01:20 AM
brianfromhawaii's Avatar
Default Car just doesnt seem to be as fast as it should be...
Let me tell you about my car. Fast 90/90, sts turbo @ 5 psi, hpe megadeath cam 244/242 112 lsa, hooker 1 7/8 inch headers, TSP ORY, whole exhaust wrapped... TRT intercooler setup... tuned at 12:1 at WOT.
I just got done with the tuning and everything and took it for a spin, right off the bat I noticed compared to it being N/A it was kind of a dog, but thats to be expected since it has to suck through like 8 feet of 2 inch pipe... so the turbo spools up and it starts pulling like crazy, but in all honesty, I expected it would pull a LOT harder... I havent put the timing to its limits yet, but it should be ~20 degrees and that seems like enough!
On a side note, while my car has been under the knife, I have been riding my R1.... maybe it just feels like a dog because I am used to the R1?
Old May 26, 2009 | 01:36 AM
35th SS's Avatar
which island you at mang?
Old May 26, 2009 | 01:39 AM
98RedBird's Avatar
Not saying this is THE problem but that cam really probably isn't helping you at all man...
Old May 26, 2009 | 01:44 AM
Silver_TransAm's Avatar
Could be your use to the bike. I just got a '07 suzuki gsxr-1000 and now my car feels like a Honda. lol
You should really get a boost friendly cam and put the stock manifolds back on to give you more bottom end with the turbo though.
Old May 26, 2009 | 02:36 AM
Big Island.
Other guys - I know the cam is not helping the low end, but wouldnt it help with the top end? I have a 224/224 116 cam laying around, maybe Ill throw that in the car to improve drivability, I am not going back to stock manifolds.... mostly cuz I dont have them anymore. Maybe there is a truck manifold y pipe kit or something?
Old May 26, 2009 | 02:38 AM
Oh, and yeah, I feel yah on the bike... I can do maybe 120 where my bike can do 150 just goofing around. 170 if i try... but my bike cant haul 3 bitches! crap... i dont have rear seats in my car anymore... hmm. bike wins! lol.
On a side note, I know the car must be making serious power because I went through 5 gallons of gas like NOTHING
Old May 26, 2009 | 08:34 AM
mike13's Avatar
With the T67 turbo it should pull pretty hard, already mentioned put I think it's the cam, that's alot of duration. Especially with the headers it's compounding the problem. I bet if you install the 224 cam the car will come alive.
Old May 26, 2009 | 09:31 AM
MY99TAWS6's Avatar
Been in buddies stock ls1 with sts .Six speed car. Seems to go pretty good really.
Timing for sure is key but too much on stock engine not a good thinkg. AFr wouldn't go much leaner than 12 to 1. Think 11 to 1 is nice and safe.A bit more boost would help think 7 or so is safe enough still. Then maybe get it dynoed. Confirm you power output.
Most turbo guys do seem to run more higher lsa cams. There are big cam arguments out there so maybe dyno both your cams for us that would be useful info to have.
Would like to see the effects on the powerbands especially.
The headers thing well local sts don't have headers and it seems to have good snap down low.
I think you are mostly just spoiled by your bike. Car power to weight is maybe 1 to 7 assuming 500 engine hp and 3500 pounds with driver for an example. You bike is more like 1 to 4 assuming 150 engine hp to 600 roughly but if its closer to 200 hp then its more like 1 to 3. Huge difference.And bikes feel faster anyway than a car.
Try to sit in passenger seat and let buddy drive it and it may seem much quicker.
Old May 26, 2009 | 09:35 AM
MY99TAWS6's Avatar
Oh in order of power output boost is first ,then timing then afr.
Less timing has advantages,easier on the drivetrain less torque and easier on headgaskets but not a worry at 5psi. I say take it up carefully to 7 or maybe 8 tops unless you put 317 heads on there to drop compression they you could try a bit higher to mabye 10psi and take timing down some maybe to 15 or so. See what that does but dyno is your friend here. Watch scanner like hawk to make sure you aren't getting any knock retard that can really steal away power.
Even check for boost leaks. find way to put a cap over piping and hook up air compressor or use automotive smoke machine.
Sure you will get that car coming around.
Old May 26, 2009 | 09:36 AM
98Z28CobraKiller's Avatar
Restricted User
Swap the cam and turn up the boost and you'll be fine.
Old May 26, 2009 | 10:45 AM
Zombie's Avatar
[redneck] We'll thars ya problem [/redneck]
I don't think your cam is hurting you unless you are floating the valves. With turbo cars that get street driven a lot I like low lift to avoid float. You should also richen up you WOT tune to 11.0 to keep the engine alive.
Someone in HI must have stock manifolds laying around, you'll not only spool faster but make more power on them due to less back pressure.
Old May 26, 2009 | 10:55 AM
SPLATT's Avatar
and you can make money by selling off the headers. Not to mention the cam. I think you will be very surprised with the results swapping from what you have to an LS6 or 224 cam, and manifolds
Old May 26, 2009 | 12:05 PM
MUSTANGBRKR02's Avatar
LT's are hurting you. Did this to my buddys car he was set on them until we dyno'd it.
Have you had it dyno'd to see the best timing not just the max?
Old May 26, 2009 | 12:22 PM
no dyno yet... i talked to STS they said that a lot of their higher horsepower guys are running wrapped headers... Id really like to find out if its the cam or the headers... the 224 is a 114 lsa.... maybe after i do some more tuning ill check it out, also i heard that if i put a boost controller on it will spool a lot faster
Old May 26, 2009 | 12:42 PM
99Z28LS1's Avatar
I wouldn't believe a thing they said unless you heard anything about the system from a member on here. STS would try to sell you a 76mm turbo for over $2k if you were dumb enough. A wrapped header would definitely not hold in as much heat as the stockers
Listen to the people on here bro. I've ran that system for almost 3 years and my car was fast with 7.5psi, TRT FMIC, 228/228 .558 .588 115LSA cam and factory manifolds wrapped and coated.
Old May 26, 2009 | 01:57 PM
heres the thing though - i already had the kit and asked them if i should put stockers back on (when i had access to them) or headers. I will phone a friend who should have the stock manifolds... and the y pipe with a cat delete
Im gonna do some more tuning, maybe turn the boost up a bit, im really not minding that much where the turbo spools at, i was just expecting a lot more punch from it.
Old May 26, 2009 | 03:02 PM
cbr600rx7's Avatar
I would have to vote for a new cam with a higher LSA
Old May 26, 2009 | 03:15 PM
Zombie's Avatar
Yeah, sure they are. STS has really gone down hill as a company and this is coming from someone that use to support them. I had one of the first f-body setups they did. I only know of one person on here that has had a rear mount setup longer than me.
Old May 26, 2009 | 04:30 PM
chris.shea's Avatar
My brother is still going to hand you your *** Brian!
Old May 26, 2009 | 04:52 PM
Chris Im sure he is hows his car doing? does he still only have the cartek cam? I havent been seeing you guys at the drags latly... hows your car doing?
Zombie - I got my hands on some stock manifolds! Damn i work fast What kinda cam would you recommend?
