What to put in Warhawk block rear vallys sensor holes ? few other questions
Ok putting together my warhawk short block. The top rear of block has two sensors holes. One im guessing is oil pressure sensor. i have that. Next one is some cam thing ? i dont have anything like that on my ls2 what do i put there ?
The mount holes for the knock sensors are bigger then the knock sensors bolts.
Can i drill out the knock sensors for bigger bolts so i can screw them to the Warhawk block?
Yes, one is oil pressure sensor, the other one you need to plug with an LS1 cam sensor.
My LS7 knock sensors fit directly onto the side of the warhawk block so I'm not sure what you have going on there.
Ok so i have to go buy a ls1 cam sensor any part numbers?
the knock sensor bolt is just smaller then the warhawk knock sensor mount bolt hole. the stock bolt is a tight fit in the knock sensor so i cant just put a bigger bolt though it
