boost creep? will Eboost 2 stop it?
its a APS kit
im running just WGs now
have not put the eboost on yet
thanks Tom
put a smaller spring, see if it changes the boost, if it does, then you know the waste gate is letting enough air out, if it DOESNT.. well.. time to see whats going on.
I can't see having to go to smaller spring either. I have to run mine up there and report back to you Tom if mine hold boost at 7.5. I do think slight overshoot is likely normal but it shouldn't stay at 10 psi. Course 10 might be fine if tune is dead on .Not the best for stock engine but maybe doable. Seen other thread here I think were guys are running some fairly high boost on stock engines but you do have your forged engine?
I would check the springs maybe you got a wrong one or something? Also leak on line to a gate could do it. check lines for any cut or line not on good just a thought.
All it can ever do, is give the base wastegate setting. So if that is higher that expected, you need to resolve that problem. Not spend money on gadgets that wont fix it.
Boost creep, if it's legit creep, is a function of insufficient waste gate flow. Can be gate size, placement, flow path to the gate, etc.
If thats not the problem, look into wastegate and wastegate pipe diameters. however I can tell you that a boost controller cannot reduce MINIMUM boost.
EDIT - AMS 1000
You can open the gate more and whenever you want with a CO2 based controller. But if there physically isn't enough flow available around the turbine, you will get boost creep.
