Twin turbo 427ci corvette / 4L80e conversion forsale MINT
Forsale...not by choice. Out of work. Liquidating assests. I will be sad to see her go.
1998 C5 Corvette 427 C5R based twin turbo with billet bellhoused 4L80E transmission. The car has 42,000 original miles. Car looks like show room inside and out. Custom motor / turbo setup / interior. I will try to list all items but I am sure I will miss some. This project has been a long time in the making with a lot of one off custom pieces. The car was built for me to keep..not to sell. All parts are top of the line...done to the extreme.
I will post pictures....I have many more including engine and transmission pictures build pictures with great detail...these are for serious buyers only (takes a while to post many pictures)
Engine:
Block: C5R Aluminum Race block. Completely debured, honed with deckplate. Billet maincaps. Cost 6500.00 new
Crank: 4.00 Callies lightweight magnum crank. Knife edged / drilled / radiused journals / beveled oil orfices / keyed
Rods: Oliver Billet heavy duty rods with ARP bolts.
Pistons: Custom on-off (not off the shelf) forged pistons. 42cc reverse dome. Thermal top coating, Anti-scuff side coating, Anti-detonation grooves. Designed for this turbo application.
Tapered heavy duty / lightweight Weisco wrist pins / spiralock
Rings: Weisco tool-steel top ring, Ductile 2nd, low tension oil rings. This setup was made for extreme abuse.
Cam: custom Cam Motion turbo billet / riffled drilled grind (Specs available if interested in buying).
Clevite Coated rod and main bearings
Clevite cam bearings
C6 oil pan with windage tray
LS3 high volume GM oil pump
Evans High flow water pump with Evans waterless coolant / hard anodized pulley
SFI approved ATI keyed harmonic balancer
A-1 Technologies MP-35 Alloy studs (main)
A-1 Technologies MP-35 Alloy head studs (stronger than any ARP bolts). These head studs cost 1000.00 290 psi tensile strength.
Felpro MLS Perma-seal head gaskets
Crane billet timing chain set
C5R Timing Chain tensioner (100.00 unit)
90mm Wilson FAST intake with all stainless hardware
Nick Williams Billet / polished 90mm throttle body
Kinsler high flow polished custom aluminum fuel rails
Heads: AFR Castings / Custom CNC’d by ET Performance. Assembled by Extreme Cylinder Heads. All seats / inserts / seals / hardware are for extreme turbo conditions. 5500.00 for hardware and labor..this does not include the castings or CNC work. Ferrara Extreme duty SS valves / Seats are copper berilium / guides are Copper berilium high temp heavy duty units / Psi double springs, shot-peened, polished 220 lbs on the seat 480 open. Cyclone titainium retainers / 7 degree tool steel locks / high temp stem seals / Flow numbers available of interested in purchasing. 250cc intake runner.
Jesel Y2K adjustable rockers with tool steel pushrod cups / full c-cliped roller tip.
Trend heavy duty 210 degree end pushrods
Morel billet High RPM / high performance link bar style lifters / allow for 7500rpm / high seat and open pressures.
Engine Management: Big Stuff 3 with wide band oxygen sensor and internal data logging option. Also has the transmission control option. Not used. This car has a Compushift control unit with custom display and control unit. Transmission control can be modified on the fly.
Relocated Coils with Magnacor custom 9mm wires. Cool Sox on plug ends. NGK 7 iridium plugs
Katech aluminum (red wrinkle powdercoat) valve covers with moroso anodized aluminum baffles. Canton -12 triple crankcase breather system.
Race Poven Nascar custom 160amp relocated alternator / Custom laser cut alternator bracket with secondary aluminum tensioner pulley.
Katech custom billet adjustable tensioner
Turbo system. All hot side and cold side piping is original PTK product (not overseas product). All hot side piping coated in Techline high temp satin black powdercoating. All cold side piping chromed.
Turbos 67mm Precision water cooled / ball bearing units. Polished compressor housing / thermal coated exhaust housings. Custom Iconel heat shields (600.00 for the set)
38mm turbosmart wastegates / 50mm Tial blow-off valve
Turbosmart Eboost 2 mounted on pillar pod with dual solinoids
Custom air to air intercooler
BeCool radiator with custom shroud / Bosch 5000cfm dual fans / custom cooling remote resevoir
Earls custom transmission and oil coolers
Custom brake resevoir heat shield
All hoses/lines either crimped or aluminum style SS of lightweight shielding
All New AC components including compressor GM
90% ARP fastners
95% GM gaskets
Custom Stinger Turbo hood
New GM Lexan top
Paint job (original) mint. Car has been covered and garage kept
Stainless B&B exhaust / 2 ½ piping with QTP electric cutouts
Custom interior matching fuel gauge in pod
Brakes : Drilled and slotted rotors / New GM pads / Tires like new.
Transmission: Custom late model 4L80e conversion. This conversion has all the top of the line internal components. It has a Custom billet aluminum bellhousing. Custom 4340 output shaft. Hardened HD input shaft, Yank SC3000 turbo converter. Compushift electronic transmission control with custom display mounted in custom dash panel.
All new driveshaft bushings (Harder more durable GM units / not BMW units.) Custom HD aluminum driveshaft with billet mount ends.
Fuel system: can hande 2000hp. Intank custom assemble (essentially duplicates the stock pickup design) but has -10 out of the tank to an external magnafuel mp4340 continuous duty fuel pump with external check valve. Y’d to -8 to each rail. Each rail out to a 1:1 pressure controlled Magnafuel fuel regulator. -8 back to the tank. Fuel system operates the way it is designed for GM. All fuel lines are Nascar style, lightweight teflon lined kevlar outer sleeve. Average price per for is 25.00-30.00 per foot. All ends are crimp style. Precision 96lb fuel injectors / flowed and tested
Z0-6 C6 shocks
Interior has custom leather “Twin Turbo” logos on two tone gray and black seats. All new gm foams. New Sport foam (complete set). Interior mint. Custom touch screen (pioneer GPS) receiver / custom radio bezel / Compushift display mounted in dash. 2 MTX amps / 4 separate components / MTX 12" sub custom enclocures with “Corvette” logo.
ESC Methanol: Custom SS Mehtanol tank inside drivers side fender with fill in cowl area / control mounted in dash panel.
Wolfe bolt in 6 pointe roll cage with swing out drivers door.
Wheels are black and silver Z0-6 inspired. Also included are 2 rear rims with ET streets mounted.
Custom brackets and dual seat bell harnesses.(red)
Misc: Parachute material two toned car cover
Car is a real must see. Real head turner. Runs smooth / absolutely mint....built to keep not sell...serious enquires only. I will also personally work on vehicle for purchaser if work is needed in the future / This is not a warranty but it is nice to have someone do the work who knows the car inside and out....
This project has approx 1000 miles on the trans/engine/drivetrain/turbos / etc. I basically finished the project only to sell it to pay off my CC I used to build her. (Since I lost my job) I have 120,000.00 invested. I am asking 59,000.00
Engine:
90% ARP fastners
95% GM gaskets
New GM Lexan top
Z0-6 C6 shocks
