Fan on intercooler??
Old May 6, 2020 | 08:42 AM
97Z28SS's Avatar
KFXguy, my point exactly my 4th gen Camaro has a huge vertical mounted FMIC (31x12x5) and water/meth with the grill area is cut out so NO restriction to the intercooler and I'm going to install dual 11" electric fans behind the intercooler and wire them to relays which will come on when the engine cooling fans do and/or when the A/C is activated. My main reasons for doing this is my car is mostly a street car with occasional track passes and while not moving or at low speeds I need as much airflow thru the radiator and A/C condensor as possible. Plus I'll have a toggle switch in the car which will turn them on along with my EWP and engine fans when I'm in the staging lanes at the track.
