Post if you have an Incon TT kit!!!!
Old Nov 10, 2003 | 11:57 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Post if you have an Incon TT kit!!!!
Please post if you have one, and whether it's on your car!!!
Old Nov 10, 2003 | 12:02 PM
ChevyNo1's Avatar
I've got one!
Stock engine ( bottom & top )
Incon TT w/ LS1-Edit tuning
91 octane
Just ran 11.59@119.24 ( corrects to 11.32@122 sealevel ) on 8.5psi with 1.70 60'
- Dug
Old Nov 10, 2003 | 12:13 PM
red ws6 99's Avatar
I have one on my 99 Trans AM
Its a Stage I setup (sorta)
9 lb of boost on 91 octane
Ran 12.48 at 115 mph on 2.0 60' at 4200 ft a couple of weeks ago
(corrects to 11.83 at 121 mph)
I have different compressor housing (just one) than Incon (slighty larger bore and considerable smoother) Also slightly different machined exhaust housing, they were clearanced by me. Also different y-pipe setup than came with the kit. Also custom oil return system.
I have the staqe II computer and injectors (no injector brackets) if anyone wants to buy it.
Gary
Old Nov 10, 2003 | 12:23 PM
rod442's Avatar
I do:
2000 formula 6 speed
503/518 rwhp on a mustang dyno 8 psi.
W. 6.0l heads and 10 psi ????rwhp, BUT
11.068 at 129.05 1.678 60' at 3860 raceweight.
Not too shabby, need more tire.
Old Nov 10, 2003 | 12:48 PM
Currdog's Avatar
I do.
Numbers in the sig below. No track times yet. A couple of pictures below:
http:\\homepage.mac.com\currdog
I'm looking to make 850RWHP, but I'm out of injector. Trying to decide on FAST/ACCEL/Impedance box now.
Old Nov 10, 2003 | 12:57 PM
ChevyNo1's Avatar
Rod, are you still running stock cam? What octane were your dyno and 1/4 done with?
Old Nov 10, 2003 | 03:49 PM
Y2K_WS6_T/A's Avatar
<<--Stage II+ Partial Kit ordered/received (if you want to call it that)/never installed/Brand New/POSSIBLY for sale.
Mir Naziruddin
Old Nov 10, 2003 | 04:03 PM
rod442's Avatar
I have a stock short (including cam), with stock unported 6.0l heads and "ls6" intake.
Dyno runs made on 93 octane, 1/4 mile runs at anything over 9 psi a 50/50 mix of 104 and 93. However I ran it on the street at 10 psi for 3 weeks on 93, sometimes 94. No problems.
DaveSchott's Avatar
Got one, it's on the car:
Incon stage I kit
SVO 42's
LS1 Edit & tune
10 psi and 100 octane
other info:
gutted pulse damper
Weldon referenced fpr
Ram clutch
Jegster loop
Deny's nitrous shaft
Strange 12 bolt 3.73
airbags
wideband
scanmaster
C5 magnesiums w/ g-force kd's 275 45 17 295 35 18
a whopping 2,700 miles on the car and less that 1k with the kit.
monterey maroon mettalic / neutral ragtop.
if the right offer came along i might let it go, otherwise I'll keep upgrading it!
Old Nov 10, 2003 | 04:56 PM
ChevyNo1's Avatar
Thanks Rod. Sounds like we're the same 'cept for the heads and intake ( I'm still stock on those too ). That's a nice MPH! I just ran a 119.24 the other day ( DA of 2000ft ) on 8.5psi and 91 . . . what timing are you running? I'm only 15 ramping to 17.
Old Nov 10, 2003 | 05:34 PM
rod442's Avatar
I am like 14 ramping to 20-22 if I remember right. 11.5:1 a/f on the 8.5 psi pre-head swap runs. after????? I will get it checked in the spring. car is parked for a long winters nap.
Old Nov 10, 2003 | 07:24 PM
Mark C's Avatar
Why all the recent interest in these kits? Thinking of ditching the YS trim?
Mine's on the car and works perfectly, and essentially has since I got it 3 years and 30,000 miles.
Old Nov 11, 2003 | 09:16 AM
LS1Tech Co-Founder
I want to start an InconTT registry, even though I don't have one the Incon phenomenon was a hot topic in 98/99 and I'd like to see how many kits are actually out there.
Old Nov 11, 2003 | 09:18 AM
ChevyNo1's Avatar
Thanks Rod . . . I think I need more timing
- Dug
