317 heads or 243s
Old Jun 23, 2009 | 12:21 AM
maxgee's Avatar
Default 317 heads or 243s
i am swapping in a low mileage ls2 motor and wanted opinions. i have 317s on my ls1 motor and was thinking of putting those on the ls2. the ls2 has the stock 243 heads on them. i wanted to try and keep the 243s for the compression, if i put the 317s, compression drops. is there a way to bring compression up without replacing pistons on the 243s?
i've been running 8 to 12 psi on my ls1 with no issues on e85 with no issues and think i can get away with 10psi on e85 on 10:9 CR.
Old Jun 23, 2009 | 12:28 AM
TurboAv's Avatar
317's and 243's are the same head. Just different combustion chamber size. Why do you want to swap them?
Old Jun 23, 2009 | 12:41 AM
maxgee's Avatar
yes, i am aware of that, but b/c the 317s have taller chamber, the compression is dropped using them on ls1/ls2 stock motors. i wanted to go with more CR than my 317s. So thinking of using the 243s. The heads are off on both motors, trying to make a decision so i can send the ones i am going to use to a machine shop for freshening up.
Old Aug 24, 2009 | 09:26 PM
maxgee's Avatar
i kept the 243s and added in ARP bolts.
just put enough miles on the clutch to break it in.
it's been 2 months since i've gotten into boost and pulled a little in 4th today, whew!! love it and missed it.
Old Sep 4, 2009 | 05:46 PM
67Firebird455's Avatar
That's awesome man. Glad you're happy with the 243's.
Old Sep 5, 2009 | 10:12 PM
VIPERKLR's Avatar
Ought to be a fun ride
Old Sep 6, 2009 | 12:21 AM
WS6HUMMER's Avatar
317's are better. A bigger chaimber = less valve shrouding.
