New APS Upgraded Turbos
Old Jun 24, 2009 | 11:11 PM
Louis's Avatar
Originally Posted by Darren P
what would I need to do to get the larger exhaust housings? I have a 403 cid engine and feel that I need the larger ones on my setup
You have to ask APS. Its a custom housing, same one used on the C6Z setup, just machined for a MHI CHRA.
I am already putting down 76x hp 87x tq at 15PSI on pump gas through a 4L80E but I know that the backpressure is getting pretty high. It will hook because I have the supension for it. It will not be ran at that power level all the time, you would have to have a boat or something to do that. I want to put the power down safely and less backpressure will help do just that.
I would be curious to know what your P/Rs are with your current setup. My new turbine wheel has drastically reduced exhaust back pressure and increased flow substantially. Its the main reason we are still able to make such high power levels with out running into a back pressure issue. We will at some point run into a restriction with the housing, thats next. The new turbine wheel will carry us pretty far, its years ahead of the stock unit. IIRC, it was circa 1990 or 1993 that that turbine wheel was from. Its standard Old school MHI stuff.
Old Jun 25, 2009 | 08:34 AM
Big_Bird_WS6's Avatar
louis. what is the spool difference. using the smaller aps turbo exhuasing.
also you never pmed me back.
why not?
Old Jun 25, 2009 | 09:18 AM
Louis's Avatar
why not?
Devin,
You will see on a 346, the spool time was 1000 rpms later than the stock 20G. The upgraded turbos spool 2-300 later than the stock 20G.
Thats a 7-800 RPM difference with the smaller housings on a 346.
Old Jun 26, 2009 | 10:48 AM
tomz28's Avatar
just ordered the turbos
and my built LS2 is in the mail
Old Jun 26, 2009 | 11:01 AM
MY99TAWS6's Avatar
Damn you!! LOL
Seriously your car should rock now with the new 402 and the new snails. I would order me up a set too but still saving for my auto trans so the snails will have to wait a bit.
At least so far my stockers are still working ok with no spyhunter smokescreen even without the scavenger pump installed. Just keep them low boost to get me thru the season hopefully. Plenty of time over winter to bolt on the upgraded snails.
Be looking foward to your new dyno and maybe track numbers.
Old Jun 26, 2009 | 01:39 PM
tomz28's Avatar
its only a 364 and i had a 145 phone bill because we talk to much LOL still working on that tune bullshit i need to fix that before it goes in
Old Jun 26, 2009 | 02:03 PM
MY99TAWS6's Avatar
Yeah had a bit of a phone bill on my end too. We can talk on xbox live if you have a 360!
I keep forgetting its not a 402. It will still be nice step up and should rev quick.
My 408 revs pretty decent actually no complaints.
Maybe will sell off a few things that have lying around and can get the upgrade turbos sooner than winter. Season is short up here end of october its time to put the cars away and they usually don't get out till april 1. Sucks but at least you don't feel guilty working on them over the winter.
You Cali guys are so lucky!
Old Jun 26, 2009 | 03:23 PM
^^^ i am still waiting on my dam billit centers. lol i talked to louis. i am going to send him my centers. and have him put his wheels on them
then we can compare journel to ball bearing
Old Jun 26, 2009 | 04:13 PM
tomz28's Avatar
how many cubes is your engine again ?
Old Jun 26, 2009 | 04:20 PM
TNTramair's Avatar
awsome info. id be all over this **** if the wife wasnt expecting in sept....
ahh well....just have to hold off a little longer...luckily i havent suffered any demise (knock on wood) with mine so i cant complain too much. these new turbos will be sweet though...cant wait to pull the trigger. might just be a Christmas gift to myself.
Old Jun 27, 2009 | 12:43 AM
377ci
6.2L
Old Jun 27, 2009 | 02:18 AM
  #32
tomz28's Avatar
ok so yours is bigger LOL
your setup is al kinds of crazy bad *** i cant wait to see how it works out im just trying to make smoething i can drive any time i want (nice days of course)
Old Jun 27, 2009 | 07:50 AM
  #33
Darren P's Avatar
I will try to find out what my P/R is and let you know.
Old Jun 27, 2009 | 10:55 AM
  #34
MY99TAWS6's Avatar
Don't hate me guys but so far at 7.5 psi my standard turbos are running just fine. No smoke no oil dripping nothing. But as Louis said likely they are ok at the standard supplied gate pressure its when you start to push them that they crap out.I have think around 1500 miles on the aps kit now. Zero problems really. No overheating in 90 degree temps so far either. I don't always run my air though sometimes just have windows down and ttops off.
I have done nothing special for cooling. 160 stat,fans come on just above that. Have added redline water wetter. Not sure how it will be on 100 degree days but we dont' get that many of those and don't have to drive the car those days.
I might crank them up near end of season just to see what happens since pretty much decided to upgrade them over winter. I can't have Tom being faster than me! LOL
Looking forward to track and dyno number with the upgraded snails.Not sure I will even bother to dyno on the standard turbos this season. and not sure will get to the track either depends if get new trans.
I think someone should take some nice pics of the swap. So sounds like while the drivers could be swapped in easily with k member on the car pretty much have to take it off to do the passenger side anyway. Not a huge deal but car needs to keep going for alignments if you drop kmember or could a guy mark it ??
Old Jun 27, 2009 | 03:16 PM
  #35
Louis's Avatar
Yep, like I said, and I try to be totally honest- Most wont see issues, but there are a TON of people With issues, so this is why we did what we did
Plus you make a metric tonne more power
Old Jun 27, 2009 | 06:47 PM
  #36
mterveen's Avatar
Default turbo upgrade price
just to confirm, the 2800 is for TWO upgraded turbos or just one and do you need our existing cores?
Old Jun 27, 2009 | 10:19 PM
  #37
Louis's Avatar
Correct, a PAIR of turbos, Ill clairify the webpage.
I do NOT need your turbos, so no down time Like I said, not much I could use, so we started over.
Old Jun 29, 2009 | 10:54 AM
  #38
yeah i went a little on the out there side. but i want to run 1000 horse on track and ****. and run 600-750 on street. and still be able to start it friday and drive 4 hours to have a weekend away.
i didnt want to tear it apart every winter.
Old Jun 29, 2009 | 07:28 PM
  #39
MY99TAWS6's Avatar
Question for Louis. I am thinking to get your upgraded turbos likely in a few months and install them over winter.
You can see my mods in my sig. I have that gt7 cam currently. Specs are nearly identical to the z06 cam..
05-07 ZO6 cam 210/230 .561/.557 –120.5 LSA
Lingenfelter GT7 208/230 .554/.546 –121CL
I like the fact the cam has no lope and just wondering will this cam still be fine to 6500 or occasionally 7000 with the upgraded snails. I think feel the power falling off a bit even at 8psi on current turbo past about 6000. So is the cam the problem and the standard turbos or just the turbos. I like the fact the cam has no surge and no lope. That suits me just fine.
Old Jun 29, 2009 | 08:16 PM
  #40
tomz28's Avatar
man i know what you mean my car is my DD right now think about that
when i do a upgrade its a weekend and thats it i dont have time in the week do to my job (U.S.MARINE) but ill race you to the dyno for that 1000 mark
hell sounds like you have alot going on that car just like my bugs all over the place. any time frame on when youll have it running?
