New APS Upgraded Turbos
Old Jun 23, 2009 | 01:52 PM
Louis's Avatar
Default New APS Upgraded Turbos
I have had these in the works for a while now as some of you are well aware of
http://www.lgmotorsports.com/catalog...oducts_id=2157
Cliffs notes-
New CHRAs, updated Turbine wheel, Billet ~60mm compressor wheel, flow 70lb/min each. This is all Im offering at this point, nothing smaller, no hybrid GT35 stuff, as this wheel blows it in the water.
These have the airflow to support well over 1000 rwhp, which is killer for any off the shelf kit
If you have any questions, feel free to ask
Louis
Old Jun 23, 2009 | 02:09 PM
tomz28's Avatar
great looking add for sure all the info one would ask and with pics
im all kinds of happy right now cant wait to have them in my hands and then in the car LOL
Thanks Louis
Old Jun 23, 2009 | 06:55 PM
airforcemanss's Avatar
are those installed and tuned prices with the exception of all the assecories (fuel injectors,etc)??
Old Jun 23, 2009 | 09:21 PM
calongo_SS's Avatar
Do you really think that? That is the price for this:
New CHRA (Center Housing Rotating Assembly)
New Inconel 71x Turbine Wheel with new 2009 technology
Billet Compressor Wheel ( ~ 60mm inducer) that flows ~ 70lb/min
New Compressor Cover machined for new Compressor Wheel
70mm Inlet so it bolts RIGHT on, no fab, no fuss, no muss
You bolt it on to your already existing turbo kit, and you tune it.
Old Jun 24, 2009 | 05:40 AM
Big_Bird_WS6's Avatar
so i have always been told billit wheels sound different. like a higher pitch. is this true
Old Jun 24, 2009 | 09:43 AM
Louis's Avatar
You can definitely hear them sing nicely at higher pressures
Correct, thank you
This is the turbo upgrade only, the kit is 6-7k, plus these turbos if you want to upgrade from the start, and install depending on tuner is 2500-4k
Old Jun 24, 2009 | 10:16 AM
Darren P's Avatar
Do these turbos include an exhaust housing?
Old Jun 24, 2009 | 11:10 AM
Louis's Avatar
No, you reuse your existing custom APS exhaust housings. We would have included one, but its an oddball T3 entry offset housing with special MHI CHRA fitment.
Old Jun 24, 2009 | 12:47 PM
MosesMcgregor's Avatar
This is really great to see!! I'm getting my APS setup tuned next week, now I wont be as stressed if I trash a turbo
Old Jun 24, 2009 | 01:27 PM
52172's Avatar
the aps f body twin kit is 8k? I think the question is that installed and tuned. Those kits were originally sold for 5k shipped intro price then went up to 5600 or something like that?
Old Jun 24, 2009 | 01:40 PM
Louis's Avatar
plus 750~ shipping, upgrade to extreme kit +1000, which is why I said 6-7k
Old Jun 24, 2009 | 04:27 PM
ok lets try again lol
base kit installed(lookin for under 700rwhp)?? does installation include running exhaust through my cme?
tune cost?
also, what gear ratios are guys running through their 9" with their m6's? 3:50's or lower?
Old Jun 24, 2009 | 06:05 PM
wforty94's Avatar
so with these turbos, the kit will probably be capable of making a tad over 1000rwhp, correct? If you plan on upgrading to these turbos anyway, can you just get the cheaper base kit?
Old Jun 24, 2009 | 06:15 PM
Louis's Avatar
These wheels have supported 1075ish at 20lbs on a 427 6 speed with the extreme kit and race gas, and there was room left, at least 2-3 more psi. I was still ~ 15 hp/psi at that point.
The Extreme kit has a larger exhaust housing, which will be necessary at some point, we have just not found it yet on the smaller stuff.
At 850 rwhp, P/Rs were still in check. I will have more data soon.
If you want to go BIG cube, 400+ I suggest the Extreme kit, as you will need the larger exhaust housing for flow. You can then upgrade those, but in reality, the extreme compressor wheels are GT35s, which flow 60-65 lb/min. That will get the job done.
The Extreme kit will need cubic inches though, on a 346, spool time was 1000 rpms later
Old Jun 24, 2009 | 06:34 PM
99 1LE SS's Avatar
Whats the recommendation for cubes and rpm range with the base exhaust housings and your upgrades. Im a lil turbo dumb but need to convert my motor from a nitrous setup to a FI setup and want to get it right the first time.
Old Jun 24, 2009 | 06:41 PM
if your not going to acknowledge my post; then you can at least pm with the prices. i don't plan on doing this anytime soon but when the time comes wouldn't it be nice to be on my top 3 list for whoever gets my money
Old Jun 24, 2009 | 07:04 PM
Darren P's Avatar
what would I need to do to get the larger exhaust housings? I have a 403 cid engine and feel that I need the larger ones on my setup
Old Jun 24, 2009 | 10:18 PM
MY99TAWS6's Avatar
Darren as you can see I am running a 408. I think the upgraded 70lbmin should be more than enough for anyone with similar size engine. How the heck do you plan on putting down more than 1000rwhp. Like to know your secret. On the street I find the standard kit at 7.5 lots of power on the built 408 estimate around 600 to 650 rwhp. Thats 700 to 750 engine and thats lots on the street. Well for most people. I admit I like to have more in reserve even if never use it so was thinking to get the 70s and just run lower boost or small shots to maybe hit that magic 1000rwhp number mostly for braggin rights .
I would not run a normal non LSX block continuously at that power level maybe I am just too conservative. I am not sure my 408 iron block can handle 1000rwhp all the time.
Too bad the extreme kit came out after already ordered my standard kit. Oh well.
Old Jun 24, 2009 | 10:29 PM
Darren P's Avatar
I am already putting down 76x hp 87x tq at 15PSI on pump gas through a 4L80E but I know that the backpressure is getting pretty high. It will hook because I have the supension for it. It will not be ran at that power level all the time, you would have to have a boat or something to do that. I want to put the power down safely and less backpressure will help do just that.
Old Jun 24, 2009 | 11:02 PM
Louis's Avatar
PM sent, I would like to keep the thread on topic, hence my lack of reply
