Help with PBV on on procharger kit.
Old Jul 3, 2009 | 02:51 PM
Ryan33187's Avatar
Default Help with PBV on on procharger kit.
Where should I connect the little outlet on the PBV and where should I put the hose that comes off the inlet hat? Post pics if possible please.
Old Jul 3, 2009 | 04:19 PM
AFASTYZFR1's Avatar
Here is Procharger Instructions:
http://www.ls1.com/ed/procharger_owners_manual.pdf
http://ktgutz.home.comcast.net/~ktgutz/ati/ati.htm
Old Jul 4, 2009 | 12:31 AM
Ryan33187's Avatar
I'm not using an FMU so what do I put the Proflow vacuum line to and the rubber hose that is connected to the air inlet hat.
Old Jul 4, 2009 | 08:54 AM
AFASTYZFR1's Avatar
What does that have to do with FMU? Those are instructions for entire kit. The small rubber hose that is on inlet hat is supposed to connect to proflow bypass. Then you connect bypass to vac source. https://ls1tech.com/forums/forced-in...elp-newbs.html
Old Jul 4, 2009 | 12:21 PM
Ryan33187's Avatar
In the instructions under Section I part 8 says to go to section K which is FMU Installation and there it says to put it into the FMU. So your saying the outlet on the proflow bypass goes to any vac source. What about this hose
Old Jul 4, 2009 | 12:41 PM
AFASTYZFR1's Avatar
you connect pcv to that
Old Jul 4, 2009 | 12:44 PM
Ryan33187's Avatar
Alright think I got it.
