5.3 and s480? yes/no?
Old Jul 4, 2009 | 12:05 PM
camarokid94's Avatar
Default 5.3 and s480? yes/no?
well i was going to go s475 at first then i figured id keep it simple and go MPT70....... now it looks like i maybe gettin a s480........ did i just "over cam my car" am i gettin a turbo t obig for my motor. i like that i should never outgrow it but in the early stages will to be to big and not work right.
early stages lookin for 600 at the wheels then slowely more to 1000. just lookin for some input. i know its a turbo and you will spend 01X more than you want but im still tryin this on a budget.
stats. nothing is set in stone yet other that i already have the 5.3, th400, ls1 head, intercooler.
forged pistons stock 5.3 bore
forged rods
stock crank.
stock LS1 heads with upgraded spring.
lookin for 9-9.5 CR
LS6 intake
i have a 32x12x4 intercooler
th400
RMVB
TB
tight stall (3200-3600)
28 10.5 et drags
low boost early stages sotck 3.23 10bolt
later the 9in out of 01 car with spool and 3.55s
i already have the 5.3 i bought it complete all acces PCM harness all for only 150. has a bad cam and 2 lifters. but those will get replaced anyways.
Old Jul 4, 2009 | 12:23 PM
Wilde Racing's Avatar
How do I change this text
What cam and torque converter? I have a S475 on my truck with a 370 engine, it spools the turbo fine. I would think the 5.3 would be laggy depending on the cam and converter..
Old Jul 4, 2009 | 12:48 PM
i was gonna go 02 ls6 for now. in my haed is kinda like puttin a 9in in a stock car it maybe to much right now but i can grow into it and not have to worry about it. but i maybe way off base here. as far as converter its up in the air as i dont know all the details on the combo right now just buy stuff and waiting for winter to put it all together.
Old Jul 4, 2009 | 02:43 PM
NemeSS's Avatar
what brand and specs of pistons?
Old Jul 4, 2009 | 02:50 PM
i have yet to get any of that yet im still in the pickin parts stage. was lookin at mahle, or some Wiseco
http://www.texas-speed.com/shop/item...d=989&catid=38
or ill keep it dead stock and see how far she will go kinda like the parish farimont
nothing is set in stone yet other that i already have the 5.3, th400, ls1 heads, intercooler.
Old Jul 4, 2009 | 07:06 PM
MeanYellowZ's Avatar
I ran the S475 on my stock 5.3 last year and it was laggy, full boost by 3800 but it was fine with me....lag is fun to me, just kinda cruises for a second, then blam....freight train
Old Jul 4, 2009 | 07:41 PM
any more info on your setup cam, compression, boost heads?
Old Jul 4, 2009 | 08:24 PM
I say run it stock for now. If you are one of the type that can deal with a small bit of lag...
Old Jul 4, 2009 | 09:20 PM
sr71's Avatar
we've got a local guy around here with a s480 on a 302 mustang with a blow thru carb. it lights up around 3500 rpms on his combo.
Old Jul 4, 2009 | 09:46 PM
more than likely its gonna be a stock 5.3 at first. lag means nothing its gonna be a pure drag car with just enough i can take it through a parade or something like that other wise 99% drag car.... one day i want 150mph trap speed
