How much overlap is wanted with a blower vs turbo?
i know it is a rather achievable goal in the diesel and rotary world..... as because the port timing on a rotary is critical to control reversion, and to keep your drive ratio in check
just saying that having a little bit of reversion from overlap with lets say a 1 : 1.3 (int/exh) pressure ratio with a turbo........ is going to be a lesser of evil when comparing the affects of overlap (bleed off) on a blower where you have a 5 :1 (int/exh) pressure ratio
again IMO
again IMO
And if you can show me a cam with overlap on a rotary...I'll be very impressed ! In fact.....
And there are many people with big cams in blowers..and they dont seem to hurt them too much.
ha... i meant that you have to watch your port shape and geometry because that controls your port duration and timing
those things are silly anyway, much better in this world
again IMO
again IMO
Maybe the exhaust and intake flow through the engine has enough inertia to where reversion does not happen or is very minimal.
After testing some cams in my old LT1 I found that more overlap equaled more power and extended rpm range (this with backpressure double boost pressure). I think my tests only included from -16 deg overlap to zero overlap however.
Overlap can be good in a supercharged car as well. Even if you do lose some of the mixture out of the exhaust you know that what you're burning isn't contaminated by any residual exhaust.
That being said I still do not run a ton of overlap or duration in most of our forced induction combinations as you can efficiently make plenty of horsepower (1200+++) with a relatively mild cam. Since most of our stuff is street driven I do not like to sacrifice driveability for a marginal amount of horsepower gain.
For example, we have used a 232/232 113lsa cam in many twin 66mm turbo 402 combinations that make 1100+rwhp at around 22psi boost and are still over 1000rwhp at 7,700rpm. These cars drive beautifully with perfect street manners. Would this setup make more power with more cam? It probably would but not by a very big margin. Again, for something street driven why sacrifice driveability and spool time for 20-30hp at the 1100+rwhp level.
We have also done many single 76mm cars that make 900+rwhp with our 225/225 113lsa cam. Would it make more power with a larger cam? In this case I doubt it as the turbo is pretty much maxed out so you would just lose low end driveability.
All these setups still seem very efficient as they are making power at reasonable boost levels and drive great on the street so I just see no reason to go crazy with the cam. With our shop having an emphasis on street driven cars I'm sure I have a different perspective on this than the guys who are strictly building race cars.
For instance, 225/225 would make 900 rwhp at 22 psi boost with the turbo max'd out. Swap to a 230/230 and now it only makes 850 rwhp, but it does so at 20 psi boost. If you want max power on pump gas, you might go 236/236 and make 800 rwhp at 17 psi. And so on... Much like adding displacement on a T4 76mm. You gain power at low boost levels, but lose ultimate hp potential at choke flow. Depends on the goals...
