Boost Bleeding Off = Bent Intake Valve?
Manifold vacuum to MAP, fuel regulator, BOV
I like to use a signal line right from the compressor housing into the appropriate port on the boost controller solenoid, then on the the gate.
At this point eliminate the variables. Separate the boost control signal from the rest of the components.
Also I did get the top of the wastegate off today. I measured the spring wire and it is what its supposed to be. There's a double O-ringed piston in it and then an O-ring between the piston and the bottom boost reference line. That bottom O-ring was torn but I thought about it and if anything it would over boost.
Yeah, its still pretty tight. The MAP is a brand new fast and actually reads a pound or 2 higher than my digital boost guage on the a-pillar.
When I did a boost leak test I did it both ways, capped and hooked up to the manifold. I actually found a leak on cylinder #8's injecter o-ring, fixed it and still have this problem. To my knowledge the MAP is good it records a boost drop just the same as the live digital a-pillar guage does.
How big of a boost leak would cause a problem like this anyway?
How do I do a valve lap test, what specificly am I looking for? I am so glad you you told me this. By testing without the WG, you can either confirm it is the problem (or the control of it) or confirm it is not the problem and look elsewhere.
Jim
Jim
Also, I spoke with JGS earlier today. They said that if the valve in the gate wasnt seating right then it would take a while to spool and its not. They also said I may just have too much wastegate for my setup but I dont see how that would make the boost bleed.
As for the spooling, that's all relative to engine size, turbo size, system design quality, exhaust back pressure and turbine size. Who's to say it wouldn't spool even more quickly with a fully closed wastegate? It is possible that you have never felt this thing truly spool properly and therefore have no frame of reference.
I am hoping we're right and when you get this resolved and feel that turbo spool better, you find your denture cream no longer works.
