Boost Bleeding Off = Bent Intake Valve?
As for the spooling, that's all relative to engine size, turbo size, system design quality, exhaust back pressure and turbine size. Who's to say it wouldn't spool even more quickly with a fully closed wastegate? It is possible that you have never felt this thing truly spool properly and therefore have no frame of reference.
I am hoping we're right and when you get this resolved and feel that turbo spool better, you find your denture cream no longer works.
Middle of this coming week to next weekend. I'm waiting on the replacement o-ring that I ordered for the bottom of the wastegate hat. I bought mine second hand but it was still new, unfortunately its an early design and the engineer James @ JGS said its a common thing for that O-ring to tear anytime you pull off or put on the hat. You can tell that the o-ring was twisted up a time or two by the way it was broken so I honestly think it was done when the hat was installed & this is the first time I've ever had the hat off. I'll def post some results.
My solution is to block off the WG dump to the DP and just let it dump to atmosphere. It was pretty much impossible to get the WG and the DP v-band flanges to line up and seal perfect, this way all I have to worry about is getting the WG inlet with the sleeve/valve seat lined up.
I should know something by this weekend & I'll post the results good or bad.
