wastegate question
Old Jul 9, 2009 | 08:21 AM
jasonpickett's Avatar
Default wastegate question
I am doing a std bore and std stroke 6.0l ls with a pt88. The turbo has a .96 ar if that matters. I plan on doing head work and a ls6 manifold. I was planning on running 15-18 lbs of boost on the street and upwards of 30psi on race gas. I was wondering would a jgs 40mm wastegate be sufficient or what would be the best wastegate to run.
Thanks.
Jason
Old Jul 9, 2009 | 09:30 AM
TiAL's Avatar
Thanks.
Jason
going to need a 60mm gate to control 15psi
Old Jul 9, 2009 | 09:56 AM
I am going to use a boost comtroler. Does that matter.
Old Jul 9, 2009 | 10:05 AM
TiAL's Avatar
nope, a 60m with base pressure of 15psi, then use the controler to adjust up to 30
the voluime of exhaust gas you will have that needs to be diverted around the turbo requires the 60mm
Old Jul 9, 2009 | 10:11 AM
vogun16's Avatar
im running a t70 with a 96 ar on a stock ls1 with a 6lb spring but its spiking 10 with a 38mm wastegate. should i get a bigger wastegate?
Old Jul 9, 2009 | 10:28 AM
Thanks. I will get a 60mm then. I appreciate it.
Old Jul 9, 2009 | 10:47 AM
MaxxMitchell's Avatar
Might need a larger wastegate. Also depends on where the wastegate is as it might beable to control the boost better is a bit better location.
Old Jul 9, 2009 | 12:10 PM
So since I am going to run a 60mm wastegate what would be a good one to get. JGS, HKS, TIAL. JGS has there 60mm on sale for $500 right now.
Old Jul 9, 2009 | 06:28 PM
stevieturbo's Avatar
Id be more concerned about the "upwards of 30psi" bit lol
Old Jul 9, 2009 | 07:42 PM
MIGHTYMOUSE's Avatar
well on the contrary for the last 5 years ive been running a 6.0 engine with a pte-88 on an innovative 42mm gate and on a 10psi spring it will hold as low as 12.4psi peak (as read by e-boost2) through 6500rpm
on the same spring ive been as high as 23.5psi steady
Old Jul 9, 2009 | 11:52 PM
I am not worried about my engine holding it. I have callies rods, diamond pistons, ls6 intake, 317 heads with 2.08 int and 1.60 exh valves. The pistons have 8.5 compression at 72cc. So my setup is not big deal. If I don't like the intake I will switch to a edelbrock carb style. I will only be running 30psi at the track. It will be 15-18psi on pump gas. As far as management it will be a fast xfi with a tci tcu for my 4l80e.
Jason
Old Sep 30, 2009 | 01:34 PM
omore001's Avatar
Jason
GL on the 30 psi and 317's without lifting them pushing water. Those 4 bolt heads just aren't going to cut it at such extreme pressures, but go prove me wrong. I'm hoping not to push any water on my built 8.5:1 370 with arp'd 317's @ just 20 psi. Aftermarket heads are necessary for big boost.
Old Sep 30, 2009 | 02:14 PM
Super Slow SS's Avatar
Yea, your not going to do 30 psi on 317's but about one time unless you plan on o-ringing some things ..
Old Sep 30, 2009 | 02:35 PM
TurboBandit's Avatar
How is your gate positioned?
I have a t70 with 8lb spring, and i hold a steady 7.3lbs boost.
Also, where is your REFERANCE pressure for your gate coming from?
Old Sep 30, 2009 | 03:55 PM
98Z28CobraKiller's Avatar
Restricted User
I tried to do it with a 44mm and couldn't drop boost below 14 psi or so. I'm using a cheapo $130 60mm with a TiAL diaphragm in it now. I dont think that you will be able to take the 317's much above 20 psi without pushing water. Thin deck FTL.
Old Nov 16, 2009 | 12:26 AM
The Fugitive's Avatar
so would it be best to go with a bigger or smaller spring to hold pressure? I have a 38 on a STS kit and at times i will see 12#s btw I have a 5.8 red spring and a 10 yellow spring combined in the 38mm. What does the spring do exactly?
