got to run the turd!!
Old Jul 13, 2009 | 12:51 PM
Rickys S/C Z28's Avatar
Default got to run the turd!!
well i got to run some yesterday found out that my car is still a turd it was 89-92 degrees all day and also got the weight of my car (3742 with driver) and this is what it ran
1St run
60 1.736
1/8th 7.225 at 97.418
1/4 11.250
no MPH
http://www.youtube.com/watch?v=6FNC4tNNiKg
2nd Run
60 1.707
1/8th 7.227 at 94.316
1/4 11.2336 at 126.059
http://www.youtube.com/watch?v=q0pIFpppQEc
all in all not to bad but i was hopeing for a bit faster im sure it will do better in the fall. i did make it to the last 5 cars in my class then the blower belt broke! had a great time today
the car also did slow down as the day went on and we had no cool down time my next to runs were 11.30 and 11.32
oh and the car dyno was 540/460@ 12 PSI today i dont think i went over 10 so that makes me happy lets me know that with some cooler weather and a race gas tune maybe the car will run some 10s? ill find out in a few months!
Old Jul 13, 2009 | 01:06 PM
02 z/28's Avatar
congrats ricky,its moving pretty good for 10 psi.
Old Jul 13, 2009 | 01:15 PM
thanks man!
Old Jul 13, 2009 | 01:24 PM
'Trust''s Avatar
That definitely isn't shabby! Nice work.
Old Jul 13, 2009 | 03:36 PM
LS1RedZ's Avatar
Nice. I am definitely waiting on cooler weather too. DA's over 3000 suck with a procharger down here in Texas.
Old Jul 13, 2009 | 03:48 PM
allthrotle's Avatar
Thats not to shabby, those are the times Im looking to hit. What kind of tires were you running Drag radials? or slicks?
Old Jul 13, 2009 | 04:12 PM
6techniques's Avatar
thats movin man! get that 60' down!!!
Old Jul 13, 2009 | 04:14 PM
MadIceV8's Avatar
Customizing Director
Nice times indeed. Would be nice to hit the 10 mark
However, what kind of CR are you running? 540rwhp seems a bit low for pushing 12psi. I would have expected close to 600.
Old Jul 13, 2009 | 04:54 PM
Schantin's Avatar
Ricky, you're a little traction away from 10's. The MPH is good for the times. Those .26 seconds are in the 60'. Cool weather will make it even faster.
Glad the car's running well for ya
Old Jul 13, 2009 | 05:33 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
10s for sure with some traction.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Jul 13, 2009 | 06:50 PM
MelScrilla's Avatar
nice runs, and it sucks about the blower belt
Old Jul 13, 2009 | 08:00 PM
blue00ZZleeper's Avatar
Nice times, 10's are close! 540 on 12psi? Whats your set up?....I make 580/550 on 9psi and I will be running 12psi soon and hope to be over 600
Old Jul 13, 2009 | 08:10 PM
kp's Avatar
kp
126mph will get you in the 10s, all you have to do is cut a better 60 foot. Cooler weather will make a big difference..
Old Jul 14, 2009 | 08:30 AM
thanks guys! my setup is a stock CI LS1 im running EPP blower cam and stock 317 heads other then some milling from when i popped the last motor my CR is 9:8:1 but, im running a 4l80 and a 8.8 with 3:73 gears.
thats why i call it a turd! LOL i know it should be faster and make more power then it does, but im happy with it
Old Jul 15, 2009 | 03:18 AM
35th SS's Avatar
Damm Ricky Congrats.yup get that 60ft down and your in the 10s.mph is good.
Old Jul 15, 2009 | 05:26 AM
thanks rex!
how much am i off on the power for my set up? i see that some of the guys seem to think im way low? any ideas?
Old Jul 15, 2009 | 07:29 AM
rufretic's Avatar
I think your car has a lot more in it than you think. My old set-up with the D1 was running times close to that, a little faster(high 10s) because my 60s were in the 1.5-1.6 range but trapping in the 126-128 range. That was in the same temperature, low 90s, the first time I took it out. Then when I took it out when the temp was in the 60s I was running low 10s and trapping in the upper 130s. Your car has good potential, it's amazing how much weather can change your times. Don't worry about your dyno numbers, the cars has proven your making good power with those traps and it being hot out. I bet you go mid tens if you work on getting your 60 down just a little, even 1.6s should get you there and of course a little cooler weather. That's no turd you got, it's quick with the potential to be fast!
Old Jul 15, 2009 | 03:38 PM
thanks man!! i hope to get it into the tens!
Old Jul 15, 2009 | 09:39 PM
I dont see why you couldnt make 10's soon, numbers seem low to me for 12 psi but through an auto its not bad. Also, numbers are for ***** and giggles.....the true numbers are the track and your car ovbiously has it there lol....better then my car atleast lol...also with a M6 on 9psi, stock bottom end and P/P stock heads I make 580rw...thats why I asked lol
Old Jul 15, 2009 | 11:30 PM
T/A KID's Avatar
Numbers seem a little off to me, was the converter locked or unlocked? What does the car weigh? How hard is the D1SC working?
Edit: Just seen the weight, your not light by no means, lol. Wait till it cools and get the 60ft down and it should do 130+ deep into the 10's
