Modified Washer Tank
It will hold anything, even fuel.
It's pretty thick. Make sure you spread it thoroughly with a plastic knife or something... Also, make sure you're following the curing process, which IIRC is 24 hours where it can be completely dry.
I've had Goop sealing up my the area where my line is tapped on my WW Tank for over 2 years now... No leaks.
