What forced induction to go with?
I want to go faster, but will leave the stock motor together as of now cause of low mileage car and don't want to go into the motor. I have been wanting to put the bottle on it, but the closer I get the more I think of going with a procharger or twins. I know nitrous helps, seen it. But which would be the best for stock motor for overall times. Don't care about hp numbers as long as it is quick. How much power can a stock motor hold without the risk of blowing it up?
This is the complete ATI ProCharger kit that I recommend. Bob
I may be wrong, but it might also depend on your shift points as to what would help to give you a faster time.. since turbos take time to spool and make power, you probably want to shift in higher rpms, and blowers make boost at idle so you dont have the turbo lag to handle and you can shift at lower rpms.. but that is just from a quick thought.. I haven't gotten much into forced induction but I want to.. just no money at the time. I plan on talking to tick performance (sponsor here and a local shop to me) about it with my goals i have in mind when I can spend the money but again, do a quick read through some stickies, it should help
i make 668whp/682wtq @ 10 psi daily driven .. with lots of room to grow ...
