anyone on here roll around without a front swaybar?
It's fine at high speeds, I have done 165mph in my car.
Just be aware that you now take corners like a 84 Coup de Ville.
Have you actually pulled your Sway bar off? Just curious if your speaking from experience or no offense.. Out your ***? heheh.. J/K.
As I mentioned before.. Seems the people who've never done this are the ones hyping it up like your gonna feel like your driving over ice.
Of all the research I've done.. Most of the folks like Noyzee that have actually pulled theirs off typically are of the opinion that it's no where near as bad as those who've NEVER done it make it out to be.
Anyhow, I"m going to actually give it a try for myself.. No biggie.. If it sucks I'll put it back on..
Just helping out. You get these muttin heads that dont even own an f-body telling people your screwed if you do it. And I know first hand it aint bad unless your road racing.
You bustin my *****?
Im going to need you to change my #'s on the boosted list. Im racing this weekend. I hope they get better!!! Im also working on my pics, I just got a couple on cd, just have to get them up.
It will help your 60' time no doubt. As you go down the track having it in or out should have no effect, as you're not turning, so the swaybar would essentially be static.
No the swaybar is not static! Eventhough you are going straight, your car tends to sway side to side, without you even noticing. Example: when parents notice that there kids teeth are crooked, what do they do? They go out and purchase braces for their child. Now if thier teeth are crooked, what are the purpose of the braces. To help keep them straight. Right! Now take those same braces and take them off before the teeth have a chance to be straightened. Then what do you think would happen(there end up going crooked again)?
Swaybars are not just intended for making turns, it helps stabilize the car at certain speeds.
Most of the poeple on this thread do not AutoX, so they dont really need the front sway bar, its safe its proven and it works to reduce 60ft and 1/4mi ETs.
you can't compare Teeth and braces to a sway bar.
If what you are tring to say is valid god help us all with the amount of people running Drag/Street Struts and springs. for that matter why even change away from factory?
I am not tring to bash you but you really seem like you have no idea.
The geometry each type of car is different but, By removing the Stock Swaybar on an Fbody does not so dramatically change the Supsension Geometry as say it would on a supra or rx7,mr2. where as those cars might be so off balance it would be a hazard to drive them safely. ( just using those cars you stated, i have no idea about them)
Removing or disconecting the Sway bar is basic weight transferance , it is not about the 14 or so pounds it weights but the about the amount of deflection it has in a negitive away towards trying to pull the weight back to the front of the car instead of the rear , am i making an sense? By removing the Swaybar the Geometry is not changed enought to make the car unsafe by any means but would i try to Autox with out it no. If i was AutoX i surely would not use Drag/Street set-up in the first place. For puttsing around town and Stoplight/Steet Light /Drag racing removing the Swaybar will have no to little noticable on those types of driving styles since they do not corner like a corner cutter would or an Autoxer will. I am trying to explain this the best way i can. the type of car sometimes will explain why a mod will or will not work. And you are correct it does not matter what kind of car you drive i worded my question poorly.
i was trying to use what ever car you had as an example to try and explain about weight transfer.
25psi,
Usually people are looking for facts from people that have actual experience, not what you consider common since.
my .02
and removal of the front sway bar might not make all that difference, but it is easier to get the wheels up/help weight transfer to the rear wheels.
not many supra, rx-7s, mr2s weighing 3600+ pounds brake the 9s. or have solid rear axels.
It doesn't take a rocket scientist to understand if you can transfer weight to the rear and reduce spin, you not only get quicker launches but more consistent track times. This is essential to winning races.
A quicker 60' WILL result in quicker ET's, everything else remaining equal... there's no question about that. And, for races where you want to dial in your time, it is ALSO essential that you be consistent, or no matter HOW fast/quick you are, you will STILL lose a drag race.
Surely you can understand that? There is NOTHING psychological about it.
