anyone on here roll around without a front swaybar?
I can move the intercooler but I dont know where to. any help is appericated.
thanks
ed
firebird455@onebox.com
Kyle
It's always a trade off...
SC-
I talked to Spohn, also, who said most aftermarket swaybars are larger and heavier, because people buying them are usually looking for better handling (which I knew) and the stock swaybar may actually be the lightest anyone could find.
I guess I thought someone aftermarket may be able to accomplish both more rigidity AND lightness. But, as you say, the lesser weight is not the major gain removing the front swaybar gains.
Nothing to loose.
Nothing to loose.
Does the front suspension have to be off the ground to remove the bar?
Thanks.
I would recomend a set of sub frames and adj shocks, But i have had a stb in and out, you cant even tell.
DONT listen to people that have never tried it,Try it your self, let us know how it works, and let us know if you run faster.
Dont forget, if your going to take it off make sure you do it all and pull the brackets to.
