Is there a way to wire your meth kit to a boost controller for safety?
Wondering if you could somehow have your methanol setup wired in to a boost controller to sense that the methanol is working. Then if it doesn't have the boost controller zero out and default to wastegate spring pressure?
i thought about doing this with one of those two stage manual controllers with the solonoid and using the pressure switch in the meth pump to activate the how side of the higher boost level, i know that my alkycontrol kit has a pressure switch inthe pump i dont know about the rest.
