Which supercharger combo to go 10.0s
Old Nov 19, 2003 | 07:56 PM
Phil99vette's Avatar
7 Second Club
Default Which supercharger combo to go 10.0s
I am looking for a new combo for the 04 season. I already have a built bottom end and just need a top end and SC.
Which SC/Boost/IC setup can I use to go 10.0s in a Corvette.
Phillip
Old Nov 19, 2003 | 08:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
M6?
I think in very general terms you need 600rwhp for 10.00's.
I'd say a Vortech T trim with some sort of cooler system should get there on 12 - 15 psi of boost.
Old Nov 20, 2003 | 12:07 AM
scottywheels's Avatar
I would say an F1 procharger with front mount innercooler. What is your CR now?
Old Nov 20, 2003 | 01:43 AM
Trojan T/A's Avatar
I was thinking about trying a Novi 2000. Has anyone used one on an LS1? I read that they are the "most effiecient" of the centrifugals, and that this blower can support over 1000hp. What do you guys think of it?
Old Nov 20, 2003 | 06:17 AM
EVIL's Avatar
phil, you have pm....
did you ever figure why so weak on the jug?
Old Nov 20, 2003 | 10:11 AM
LS1Tech Co-Founder
Novi 2000 is a nice blower too.
Old Nov 20, 2003 | 01:09 PM
Crunch's Avatar
600RWHP will not be enough to run 10.00 with a full weight Corvette and an M6.
You will need closer to 700RWHP and 700RWTQ. Look at No Mercy's car and SW's car for example. Also, Harlan went 10.000 with 700RWHP.
600 should be good for high tens with an M6, mid-10's with an auto.
Old Nov 20, 2003 | 02:03 PM
7 Second Club
How high are you guys spinning the motors?
Phillip
Old Nov 20, 2003 | 07:59 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
600 should be could for high tens with an M6, mid-10's with an auto.
I went 10.91 with a ARE 6.0 liter and a D-1 6sp@3840 lbs in a camaro ss.Car made 565 rear wheel.I think low 10's could be done with 525rwhp in a C-5.
Old Nov 20, 2003 | 09:58 PM
Crunch's Avatar
If you went 10.9 with 565 HP, how can you run nearly a full second faster with 40 LESS horsepower? Granted, the C5 is a little lighter, but not THAT much lighter.
Phillip, 600RWHP can break 10.00's with a TH-400, transbrake, slicks, skinnies, and a very light car. But who wants to do that with a nice C5 Corvette?
Here's a link to SW's car that ran 9.98 with over 700RWHP, 3200 lb raceweight, and perfect shifting. If you can do that with only 600RWHP, you're freakin' God man.
In my opinion, you'll need a lot more than a D-1SC or Vortech V2-SQ to run 10.00's without gutting the car and switching to an auto tranny.
Good luck.
Old Nov 21, 2003 | 02:13 AM
hey crunch I am 600 rwhp and I went 10.30 in july. I will go in the 9's once the tranny is fixed with still only 600 rwhp
Old Nov 21, 2003 | 06:20 AM
Crunch's Avatar
Phillip has a C5 corvette with a six speed.
I'm not saying its impossible, just not bloody likely.
Old Nov 21, 2003 | 12:22 PM
LS1Tech Co-Founder
Crunch, I think that you are handicapping stuff too much.
700rwhp at like 3400 raceweight is good for 9.30's in auto car. So it's only good for 10.doh's in a stick car? I'm not just LS1, I am JUST talking about 700rwhp.
600rwhp with a stick, slicks, 3400 raceweight, and a good driver will go low 10's.
Harlan went 10.doh but the mph is indicative of mid 9 second potential.
Old Nov 21, 2003 | 12:49 PM
Crunch's Avatar
Show me a six speed supercharged LS1 Corvette with 600 peak RWHP that runs 10.00.
No Mercy and SW did it, but with another 100RWHP, and with nitrous - NOT a blower (i.e. monster torque, and no peaky HP impeller).
I'm not trying to handicap Phillp's car before it even gets started, I'm just being realistic, based on the hundreds of racing videos I've watched.
For example, theres a guy over on the Corvette Forum that just went high 9's with a D1-SC. But guess what, that was also with a 150 shot of direct port nitrous!!
Like I said, good luck, but don't be dissapointed if it doesn't run 10 seconds flat with only the supercharger.
Old Nov 21, 2003 | 01:44 PM
S_J_H's Avatar
I think what has happened is guys get confused with heavy street combos vs lighter race combos when they discuss parts.
The street combos waste a LOT of hp. I am guilty of that as well but am going the strip route now.
You need to look to the other camps for reference of what is possible simply because there is not enough hardcore ls1 blown combos running around.
For instance, street renegade Ford 306ci, Vortech Sq trim, stock TFS heads and STOCK factory cam- just ran 9.94 at 135mph.
So lets' see here fellows..
The car has less cubes, smaller S trim blower, a ridiculous small stock cam,and unported TFS heads yet ran a high 9 at 135mph.
That's a nice very efficient use of parts.
You do NOT need a huge blower or any additional nitrous if you choose your combo properly and are primarily building a strip car simply to run 10'.0s.
Plus the tuning is huge in making or breaking the combo. Pump gas is also a biggy in holding guys back with the power.
Steve
Old Nov 21, 2003 | 02:02 PM
LS1Tech Co-Founder
Crunch what was the mph on that guy's run?
Old Nov 21, 2003 | 02:21 PM
Crunch's Avatar
The original question that started the thread was which supercharger kit will get a C5 Corvette into the 10.00's. This is not about F-bodies and Mustangs.
All I'm saying is based on the hundreds of races I've seen, I don't believe an ATI D-1SC, a Vortech V2-SQ, Magnacharger, or any other off-the-shelf blower kit will be enough to get a C5 to run that time. You will either need a shot of nitrous, more cubic inches, and/or some SERIOUS weight reduction.
Let me put it this way:
I'm assuming Phillip plans on putting a blower on his current C5. As of right now (according to his signature), he's running very high compression, a very big cam, with a 111LSA, and spinning the motor very high. By the time you finish undoing all of this to get ready for a blower, the car would most likely be back up in the high 11's.
Then add the supercharger.
Now if you guys are trying to convice Phillip that he can just go buy one of these blower kits, and then go to the track and jump from high 11's to 10.00's.... C'mon.
Old Nov 21, 2003 | 02:24 PM
Crunch's Avatar
138mph
Old Nov 21, 2003 | 03:02 PM
S_J_H's Avatar
No, I agree it is a big change and will take a lot of work and No "kit" is going to do it for you. Kits are basically just starting points IMO if your building a race combo.
Going from high 11's to 10.0s is nothing if your going to build a real blower combo. Plenty of 8 sec cars that would probably be in the high 11's if they removed their turbos or blowers.Of course the rest of the car has to be able to utilize the power.
But you can't think of a blown motor like that, a blown motor is built around it's supercharger/turbo.
It's a complete combo.
Old Nov 21, 2003 | 03:29 PM
LS1Tech Co-Founder
Of course, Crunch you are just another lowly F-Body guy like Steve and I right? I don't see a Corvette in your sig.
Sorry, but take SW for example. He went what, like 10.8 on motor? And what on spray? He was spraying a single TNT kit so maybe 150-200 shot through the throttle body? I doubt he made 700rwhp with that car.
Take your 138mph example. It says nothing about how the guy drivers, how he launches, what tires he's on etc.
