Question about Boost Gauge
Old Nov 21, 2003 | 08:53 AM
BlackBootyZ71's Avatar
Default Question about Boost Gauge
why do most people have a boost/vac gauge instead of a boost only gauge?
Old Nov 21, 2003 | 09:17 AM
additionally, does it matter if the gauge is mechanical or electrical?
Old Nov 21, 2003 | 10:30 AM
Texas Terminator's Avatar
'cause it's cool. and knowing the engines vacuum can help diagnose some problems. as far as mechanical or electrical, you will get mixed answers. electrical guages are usually easier to install, no plumbing to mess with.
Old Nov 21, 2003 | 10:35 AM
Crunch's Avatar
Well, I'll try to explain.
Atmospheric pressure is 14.7PSI. In terms of high performance and racing, boost is anything over 14.7PSI, and vacuum is anything less than 14.7PSI. And since the whole purpose of blowers and turbos is to create boost, we generally use 14.7PSI as a reference point. Therefore, zero PSI on a boost gauge is really 14.7PSI of atmospheric pressure, and -14.7PSI is no air pressure at all. When the blower/turbo is not working, the bost gauge will show close to -14.7PSI, which means the engine is sucking in air on its own. When you drop the hammer, and the boost gauge jumps to anything over 0 PSI, those positive values represent how much air pressure the blower/turbo is forcing into the engine, in addition to atmospheric pressure.
All boost gauges show numeric values from -14.7 up to whatever boost you plan to run. Mine goes to 20PSI.
Old Nov 21, 2003 | 10:54 AM
so basically on a boost only gauge, you have no idea if you are running less than 14.7psi of boost correct? (because it would just sit at 0, as opposed to showing a negative number?)
seems like (as stated above) that this would be a better diagnostic tool.
As for the elec vs. mech. part goes...how do you tie the gauge into your electrical system to monitor boost? (i can understand the mechanical gauge just taps right into a line)
Thanks again for the help.
Old Nov 21, 2003 | 11:31 AM
Crunch's Avatar
From what I understand, both the digital and analogue boost gauges are hooked up the same way. Its just that the digital version contains a chip that converts air pressure to voltage, and hence the digital display. I assume there is another wire to connect it to the car battery to power it, or perhaps they come with their own lithium batteries.
Old Nov 21, 2003 | 11:34 AM
good deal, so in your opinion...should i just keep the boost gauge they are sending me, or return it for a boost/vac gauge?
Old Nov 21, 2003 | 11:41 AM
Crunch's Avatar
They who?
If someone is selling you a kit with the blower and gauges, it is probably a boost/vacuum gauge. It just may not say that on the box. The Autometer boost gauge does not say anything about vacuum on the box, but it clearly has values below zero.
Old Nov 21, 2003 | 12:49 PM
They who?
sorry for the confusion! I ordered the Autometer Cobalt Series Boost Gauge from Thunder Racing...and was wondering if I should send in back in favor of the boost/vac gauge.
Old Nov 21, 2003 | 01:08 PM
black_yukon's Avatar
The e-boost gauge sets up just like the mechanical, but the e gauge taps into an electronic sender that mounts under the hood. The sender has wires that you route into the car and plugs into the boost gauge.
Old Nov 21, 2003 | 01:11 PM
Crunch's Avatar
It is a boost/vac gauge. I have the same one, but black & yellow, not cobalt.
Old Nov 21, 2003 | 01:31 PM
hmm, they had 2 seperate part #'s
6160 is a 0-30psi boost only gauge
6159 is the -30:30psi boost/vac gauge
Old Nov 21, 2003 | 02:30 PM
Crunch's Avatar
Really?
Did you order that yourself, or is that what came with your kit?
In that case, get the 6159, or else you will have no reading unless you are on full throttle.
Old Nov 21, 2003 | 02:47 PM
Really?
yeah, i ordered it myself from TR
Old Nov 21, 2003 | 02:52 PM
since the gauge was backordered, i was able to change to the boost/vac with no problem...thanks again for the help
Old Nov 21, 2003 | 05:10 PM
Assassin's Avatar
[/QUOTE]Well, I'll try to explain.
Atmospheric pressure is 14.7PSI. In terms of high performance and racing, boost is anything over 14.7PSI, and vacuum is anything less than 14.7PSI. And since the whole purpose of blowers and turbos is to create boost, we generally use 14.7PSI as a reference point. Therefore, zero PSI on a boost gauge is really 14.7PSI of atmospheric pressure, and -14.7PSI is no air pressure at all. When the blower/turbo is not working, the bost gauge will show close to -14.7PSI, which means the engine is sucking in air on its own. When you drop the hammer, and the boost gauge jumps to anything over 0 PSI, those positive values represent how much air pressure the blower/turbo is forcing into the engine, in addition to atmospheric pressure.[QUOTE]
I guess thats where the ricers think there running 20psi and why a rental car would give them a run for there money, lol
Old Nov 21, 2003 | 05:21 PM
LS1Bird's Avatar
You'll be glad you did. It's cool to watch the needle bounce around just itching to go to Boost!
Mike M
Old Nov 23, 2003 | 09:14 PM
MEAN LT1's Avatar
Mike M
Tell me about it, especially with these cobalt guages. They are pretty nice guages.I like the auto centering feature on both the fuel pressure and boost guage.
Old Nov 24, 2003 | 12:15 AM
OOsilverado's Avatar
Definately go with the electronic gauge.
Aside from the fact that you have the ability to diagnose problems better because you see vacuum, the electronic gauge also has a warning light and memory, so you can see what your peak boost is and if you overboost.
Old Nov 24, 2003 | 09:00 AM
MEAN LT1's Avatar
Where is this feature at, I have both the cobalt boost and fuel pressure guage and dont see it.
