Ran today on street tires.
9psi of boost
60' 1.86
1/8 7.14 @ 105
1/4 10.77 @ 136
DA was 3041 which was not too bad since it was 95 degrees.
Check this...raceweight was 4095#
I think I can get a 10.5x out of it. I think I am more excited about this than the 9.59s on slicks.
SD- standard definition
HD- high definition (FAST computer)
SD http://mssftw.com/videos/SD-10-77-streettires.wmv
HD http://mssftw.com/videos/HD-10-77-streettires.wmv
Do you use a ramping on the boost controller? I blow my 275/17 nitto drags off in 1st and 2nd and some of third at only 8psi with my 408 with 3.54 gears.
When I tried my nittos at local track even prepped days with other cars and lower power levels can't get a 60 ft below 2.0 on them if my life depended on it and you get this amazing 60ft with not even the drag nittos.
Great job for sure. Must be hard to keep it off the wall though on those.Or GOD himself must prep that track.
I set my Koni DA shocks to:
front- 10 clicks hard on compression...full soft on rebound
rear 3 clicks on compression....1 turn from full hard on rebound
no front swaybar
i footbraked it to like 2700 rpms i think
some of the weight is:
iron block +80
4l80 +80
roll bar +60
8.8 rear +20
boombox +50
turbo +50
intercooler +30
