Remote Turbo charger?
Old Nov 23, 2003 | 06:37 PM
I8Your03Cobra's Avatar
Yeh its loud the turbo whines like Hell too
people are going to know yor car is turbo for sure!
Old Nov 23, 2003 | 07:52 PM
Cld12pk2go's Avatar
Joedirt/Rick
Was the correction factor for the LS1 dyno also 1.23 like for the LT1?
Old Nov 23, 2003 | 08:47 PM
LSs1Power's Avatar
I would love to see the dyno sheet for the LS1. Also could we ask for an Air to Air intercooler?
Old Nov 23, 2003 | 09:01 PM
Smoke_Ford's Avatar
What kind of gas are we gonna need to run to be able to safely run 5 psi?
Old Nov 24, 2003 | 05:00 AM
Smoke_Ford's Avatar
to the top
Old Nov 24, 2003 | 09:14 PM
BigPlanTransAm's Avatar
awesome idea. i am constantly thinking of a better way to make things work but it looks like you guys beat me to this one .anyway, i will definately be following this closely so heres a and a TTT for ya
edit: about the methanol injection, you say it reduces intake temps so where is it being injected? right after the turbo? i have heard of water/alcohol injection systems before but they are injected into the cylinders but i dont see how that would reduce intake temps. can anyone explain the concept to this simpleton?
Old Nov 24, 2003 | 09:59 PM
JoeDirt's Avatar
Here is the dyno graph of stock LS1 vs STS
Here is the dyno graph of low boost vs high boost
Here is a dyno graph of just high boost
Old Nov 25, 2003 | 12:43 AM
Cld12pk2go's Avatar
Joedirt/Rick
Also, I cannot tell which run had the A/F ratio heading close to 13:1 over 5k RPMs (the scan is difficult to discern between the two runs). It would make sense to me that it would be the 5 PSI run would be leaner with stock injectors and no added methanol; however, I just want to clarify.
Oh, and damn nice work.
I know you are making good power with the T60-1 turbo; however, I still believe that something in the T-76 range would be a much better compressor match for the LS1 flow requirements.
I know this might detract from the budget focus of your kit; however, I am curious about your thoughts on using a larger turbo. Would it perform well remotely mounted? Turbotech reaches 10 PSI by 3500 RPMs on their T-76 turbo kit. I am just trying to see something comparable would be possible in the remotely mounted location.
Tks
Old Nov 26, 2003 | 02:28 PM
Smoke_Ford's Avatar
still gotta know what kind of gas is needed to run this much boost safely.
Old Nov 26, 2003 | 03:14 PM
elcheapo's Avatar
I am also very interested in this kit, i will probably buy it as soon as i know it's as good as it sounds. I'm interested in a few things, #1 what octane is needed for
Old Nov 26, 2003 | 03:15 PM
elcheapo's Avatar
I am also very interested in this kit, i will probably buy it as soon as i know it's as good as it sounds. I'm interested in a few things, #1 what octane is needed for 8psi, and i'm not sure about the methanol cooling, how hard would this be to install? -very interested
Old Nov 26, 2003 | 03:18 PM
  #32
they have a generic calculator on thier site, it seems you would need some pretty high octane to run this kit at all considering our 10-1 compression stock
Old Nov 26, 2003 | 03:22 PM
  #33
KHShapiro's Avatar
time will tell if the numbers are accurate
Old Nov 26, 2003 | 05:33 PM
  #34
CHEAPO 93 octane ,methanol cooling has been around sence the 60's, alot of the gradnational guys use it too!!Its about as had as installing a catback 4 hour install for first timers
Old Nov 26, 2003 | 09:03 PM
  #35
elcheapo's Avatar
sweet!!! I'm really looking forward to this, amazing hp per doller ratio, can't wait till this kit comes out! I have about that much money to spend on mods this year, and that's even more power than i was looking for, even if these dyno's are slightly optimistic i'm getting one of these, as long as the quality is there.
Old Nov 27, 2003 | 09:23 AM
  #36
Rok's Avatar
Rok
one question with the methanol. Is it hard on the engine? wear and tear wise?
Old Nov 28, 2003 | 01:50 PM
  #37
so you could run 8psi on 93octane and methanol with a stock (bolt-on) engine?
Old Nov 28, 2003 | 02:29 PM
  #38
Originally Posted by JoeDirt
Thanks, Rick @ STS
LS1 Dyno Test
Tested the 99 LS1 prototype on 11/22/03 at Phantom Motorsports in SLC. Results were:
Stock this same car produced a best run of 320 rwhp on this same dyno.
5 psi run produced 416 rwhp and 452 rwtq
8 psi run with methanol injection produced 509 rwhp and 551 rwtq
These runs were on a completely stock LS1 with STS turbo system and no other modifications or tuning. Will have the dyno charts posted on the site soon.
Kits will be 3000 - 3500 $ I beleive
thats with stock injectors fuel pump also? i've always heard the stock fuel system would support ~450
Old Nov 28, 2003 | 06:19 PM
  #39
JoeDirt's Avatar
Well that would explain my nitrous dyno ( dry ) It hit 440 rwhp 560 rwtq before I went lean and the computer took all my sparkies away
Old Nov 30, 2003 | 10:36 AM
  #40
Stock fuel system and no tuning ,But tunning is advised (of coarse) over 5 psi! The methanol is not hard on the motor is not a strong mix 50/50 water methanol, Winshield washer fluid for your car will almost work thats a 70/30 mix 70/water and 30/methanol
(Big) 8psi is safe too run on the stock bolt on motor from what I have researched you can get away with 10psi on the stock motor just not sure for how long!!
O yah did you guys know that they are making this kit bolt up too your long tubes!!!!!!!!
