timing with a low compression turbo setup
Old Aug 13, 2009 | 03:46 PM
lt1camaroman93's Avatar
Originally Posted by black98ws6ta
With a 408, 13 psi, 26*, air to air, and e85? That's a interesting mix.
Leaves on low boost and ramps to 12-13 about 5 seconds into the pass and just stays there.
Old Aug 13, 2009 | 05:14 PM
ninetres's Avatar
What size turbo? <---did I miss it? Funny no one asked this very important question before questioning his set-up lol.
Old Aug 13, 2009 | 08:04 PM
I know, funny isn't it? Large frame 80mm.
Old Aug 14, 2009 | 07:52 AM
cablebandit's Avatar
are you ramping it that slow for traction?
e85 is good stuff. I ran a few tanks of it but the gas mileage sucked. I would run it at the track but I dont have enough fuel system to support it.
Old Aug 14, 2009 | 09:39 AM
Yep, I run a 8.90 class so I'm trying to get the car as consistent as possible even for shitty track days. This is my first time building/setting up a turbo car and the whole car is a new build so its taking me some time to get everything dialed in. I had suspension issues for a while, but those are all figured out now.
Old Aug 14, 2009 | 09:12 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Thanks for sharing info on your combo, it's very interesting to hear about a combo running a lot of timing and running strong. And you are 3100 - 3200 raceweight?
Old Aug 14, 2009 | 11:16 PM
3100-3150 I'm foolish for posting all this crap on the net, but it is what it is. I'm happy with the way the car runs and my goal was to go 8.80's with this setup. I think with a bit more tweaking I should be able to get there.
