Piston to valve contact, are my pistons trash now?
Anyway, a week before I overboosted I installed a set of Patriot extreme springs so I doubt I floated the valves then. To just look at the heads the valves they look as if they have never made contact. I know they are probably bent but to look at them they look like they are seating just fine, I have driven it twice after the overboost and it runs/idles & drives like it always has.
Restricted User
So this is good news if the valves are bent. Throw the other heads on there and see if you find some cheap power. If they have been like that for a while then they should be fine for another while. The ****'s stock anyway so if it does blow up, it's not the end of the world.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
