Negatives of restricting blower inlet vs. changing pulley to get less boost
Old 08-16-2009, 09:45 PM
427's Avatar
Restricting the inlet puts less strain on the blower and increases the under the curve boost. All my testing showed no change in temperature.
Kurt
Old 08-16-2009, 10:16 PM
Mr.Big's Avatar
Kurt
I've tried, maybe they'll listen to another person that's also actually done this, rather than assuming what they "think" would happen... Restricting is the way to go... promise...
Old 08-17-2009, 07:02 AM
engineermike's Avatar
Restricting the inlet will not increase the temperature over non-restricted. However, the IAT will be much higher than it should be. For instance, if it's pullied to make 20 psi (say 250 deg discharge), then you restrict the inlet to get 15 psi, the IAT drops slightly to about 240. Pulley it down to 15 psi and the IAT would drop to 200. It's physics and this can not be disputed.
At work, we have some air compressors that pull from atmosphere and discharge at 8 psi at roughly the same flow rate as an 800 hp motor would need. They are very similar in flow and hp to a large supercharger. However, the discharge temps are in excess of 350 deg F because we restrict the inlets to manipulate flow rate.
Old 08-17-2009, 08:15 AM
rufretic's Avatar
Kurt
Great info guys, makes me a little more comfortable in my choice. How do you guys go about restricting? Is there something actually made to put on the inlet?
That's exactly how I understand it which is fine. My IATs are fine right now, so by restricting it, I'll have a little higher IATs @ 20psi than if I pullied down to 20psi but yet they won't be any higher than they are now with the 25psi, so they will still be fine.
Old 08-17-2009, 09:42 AM
Mr.Big's Avatar
here's one way... this is the intake pipe (filter to head unit)
http://www.youtube.com/watch?v=nAG1enBPwso
Quick Reply: Negatives of restricting blower inlet vs. changing pulley to get less boost
