Done for the season
Old Aug 15, 2009 | 06:21 PM
HUNTER02SS's Avatar
Sounds like a grounding issue??? Mt old car used to backfire and carry on like you are describing. Through searching, I found a broken ground wire in the PCM Harness and then added a few more grounds and the issue was gone.
Old Aug 15, 2009 | 06:42 PM
biggdogg's Avatar
Had a problem with my bigstuff 3 it wont commicate with my computer after i drove 2 hrs, to the dyno loaded up went home sent it to bigstuff they fixed it quick and sent it back put it back in car loaded up and drove 2 hrs back to dyno got it tuned been fine since.Going fast aint easy if it was everybody would do it.your so close to the 7s hate to see you give up goodluck...
Old Aug 15, 2009 | 09:44 PM
veee8's Avatar
Hang in there.... you guys will get it figured out.
Old Aug 15, 2009 | 11:31 PM
6techniques's Avatar
PLEASE work it out man, I think I would leave the site and go back to stangs if you parted that monster out. (or at least think about it.) Hopefully things will go smoothly with BS.
Old Aug 16, 2009 | 12:35 AM
98Camarod's Avatar
Just keep your head up and don't make it an ugly break up, you two can work it out
Hopefully they can work something out for you on the BS3.
Old Aug 16, 2009 | 10:20 AM
Shawn @ VA Speed's Avatar
Brian is pretty disgusted right now with having these ignition issues.After spending a good portion of money on "the fix" it's kinda disappointing to have the same isuues.
We know how to fix it properly,just costs money and takes time.
I'm pretty confident you will see this car again on the racetrack running better than ever.
Old Aug 16, 2009 | 10:30 AM
theblur98ss's Avatar
I know the feeling all too well. Take a break and see how you feel down the road. On a side note is this a known problem with BS3? My bs3 car is backfiring on the initial startup. I just figured the tune wasn't where it needed to be.
Old Aug 16, 2009 | 01:32 PM
TwnTrboCE's Avatar
I know exactly where he is at. But a whole lot deeper in the hole thinking I had "the fix" at the time of purchase. All I can say is thank God for sponsors or mine would be for sale also.
Hang in there Brian, and if you do the setup like Kurt is doing. The cost of the change over isn't that high when you see how much a Jessel belt drive is. Plus you will know this will fix it. Good luck man!
I'm at the belief now that if your looking to make over 1500hp and run it above 7,500rpm that you should run a distributor setup.
Old Aug 16, 2009 | 01:36 PM
TwnTrboCE's Avatar
It's becoming a know problem with high reving high powered cars. There are a lot of other things that can cause a backfiren issue though. If you don't have the new firmware from BS3 you need to get it. So you can first verify your cam/crank advance.
Old Aug 16, 2009 | 01:39 PM
Phil99vette's Avatar
7 Second Club
I agree on the distributor part 100%. We have not had one hiccup this year, I think we perked Brian's interest when he regapped a new set of plugs we installed them and proceeded to go 163mph to the 1/8. He said "Damn imagine what my car would do with an ignition that works".
Old Aug 16, 2009 | 01:43 PM
veee8's Avatar
I will keep mine to 1450 hp, so I don't have to run a dizzy!
Old Aug 16, 2009 | 02:02 PM
  #32
TwnTrboCE's Avatar
I didn't want to have to do it because we haven't had to for years. But now wish I would have when I first had the backfiren start. I could have paid for the change over with the money wasted on "fixes".
Congrats on another win and the sick mph. Love to see the little LS motors on top. I was hoping to run in the high 150s when it's back together. Guess I'm going to have to turn it up! How much boost did you get to on that pass?
Old Aug 16, 2009 | 05:26 PM
  #33
7 Second Club
Average boost 24.51
Peak boost....mid to high 30s. The boost curve left ALOT of power on the table.
Old Aug 16, 2009 | 09:34 PM
  #34
jasonmurry69's Avatar
there is alot cheaper way to add a distributor then going with the jesel setup i did mine for like a total of 500 bucks roughly!
Old Aug 17, 2009 | 06:20 AM
  #35
Fireball's Avatar
I'm looking at the GMPP setup too. How the hell can you do that for 500? That just about covers the GMPP conversion kit only
Old Aug 17, 2009 | 07:41 AM
  #36
98Camarod's Avatar
He knows a guy that knows a guy that robbed some people.
There's a lot of support in here. I know it doesn't pay for the build, but it should be worth something.
Old Aug 17, 2009 | 07:56 AM
  #37
Fireball's Avatar
I'm just weighing options...
looks like there are really 3 options:
1. Jesel camshaft belt drive + MSD belt drive front mount dist. VERY VERY expensive, but this is the proven combo
2. Kurt Urban MSD belt drive front mount that works with factory cam setup. Much cheaper than #1 and should be as good as #1
3. GMPP camshaft setup + MSD Ford Distributor. Cheaper yet but somewhat unproven, though just about any ford out there runs this type setup so it shouldn't be "high risk"
Either way, would also need:
Coil
MSD Flying magnet trigger wheel
MSD non-magnet pickup
MSD box (most likely 7AL-2)
BS3 reconfigured into distributor mode
BS3 distributor main wire harness
BS3 3 step harness for MSD
Old Aug 17, 2009 | 08:04 AM
  #38
Sharpe's Avatar
Good luck with everything!
Old Aug 17, 2009 | 08:56 AM
  #39
hellbents10's Avatar
LS1Tech Sponsor
Have you tried the external crank trigger from BS3 along with the MSD cam sensor set up?
Old Aug 17, 2009 | 09:10 AM
  #40
Fireball's Avatar
its not cam/crank related. I had my BS3 updated and ran their external crank trigger. Advance held constant and it still backfired.
