Ls-7 compression
Old Aug 15, 2009 | 11:32 AM
gee man's Avatar
Default Ls-7 compression
Whats your guys opinion on compression selection for a disc powered LS-7. Would you go high with less boost or low high boost combo.The car is 3700lbs with a 6 speed .I was hoping to get 7oo to 800 rwhp . Is this possible with the stock heads and cam? I guess meth would be a good idea as well.Any input on this would be greatly appreciated. I am chomping at the bit to get going on this. Thanks
Old Aug 15, 2009 | 02:01 PM
ddcarter's Avatar
I am in the same situation. I am leaning toward high compression and low boost, something around 5-7 pounds. I know of people running around 11:1 making almost 700 hp with stock bottom end.
Old Aug 17, 2009 | 04:51 PM
Drewstein's Avatar
Low compression with high boost will be easier to tune etc. No reason to go with high compression if you have the choice i.e. don't already own the motor.
