who runs high comp low boost?
Old Aug 27, 2009 | 01:22 AM
EmanGoat's Avatar
I am in the same boat as the OP, but I dont yet know what type of blower I want to go with, or what type may be more friendly with the higher compression: tvs 2300 or centrifugal? I'm running a HKE 408 with 11.44 compression. Thoughts?
Old Aug 27, 2009 | 07:52 AM
c5andtyphoon's Avatar
its hard to get a good answer, it looks as if we are going to have to go on full race gas tunes. or lower are comp
Old Aug 27, 2009 | 08:47 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm sure that most of you guys know that C16 is like $10/gallon.
Old Sep 26, 2009 | 07:29 PM
Spd-Kilz's Avatar
I'd like to bring this back up to the top.
I'm interested in doing the same as the OP. I never cared for boost before, but now I wouldn't mind adding some conservative levels of boost.
11.5:1 comp + 94 octane + Methanol Injection
I realize a lot has to do with the tune, but how "safe" would this setup be? How much boost would be a good level? 3? 4? 5 PSI?
Old Sep 26, 2009 | 08:06 PM
383lt1impala's Avatar
10 bucks a gallon? How much is q16? About the same?
Old Sep 28, 2009 | 01:19 AM
lt1camaroman93's Avatar
~10.5:1 and 15psi with a 80mm turbo and E85 here. Stock iron block and stock 317 heads. If I try 16psi the heads lift. This could be many of things though; wrong cam, to much timing, or to thin of a head deck. No clue what it makes hp wise, but its enough to go 15x mph out the back door in a 3k lb car.
Old Sep 28, 2009 | 03:18 PM
i think that i seen you around before. over at speed unlimited and at us41, i was at us41 with straightline performance. red c5. and i seen you at speed unlimited i was with my brother in law with our turbo busas
who does your tuning? i would be very interested in doing a large blower/turbo on my 11.5 to 1 408, on a e85 tune
Old Sep 28, 2009 | 05:24 PM
AVB's Avatar
AVB
What's a good cam on a setup like this?
