What are you guys doing for fuel pressure in your 600+ vehicles?
Old 09-05-2009, 10:26 PM
jomomma's Avatar
doesnt the second pump opperate off a hobbs switch? to only operate when in boost?
Old 09-05-2009, 10:57 PM
vipvegas's Avatar
Im wiring my secondary pumps relay to trigger off the oil 1psi switch used for the sts.. Should work perfect. So any time I get into boost the pump kicks in..
VIPERKLR's Avatar
just put a 255 inline with rpm box its the easiest
Old 10-09-2009, 09:05 AM
blazin's Avatar
Hey Zombie do you think you are at the limit of the stock system right now? We are shooting for 750-800 and want to get all the stuff that is neccesary out of the way now but if stock will hold up that would be fine also.
Old 10-22-2009, 05:12 PM
vipvegas's Avatar
Twin walbros are in. Stock feed, 79# injectors. Do I need a adjustable FPR at this point or should I be able to get away without it.. Also if needed, what do i need extra to install. Any writeups as Ive used the crappy search button to find nothing. Will be running 15-16 psi max
Quick Reply: What are you guys doing for fuel pressure in your 600+ vehicles?
