Another Turbo camsgaft thread !!
Latest is Kelford cams have offered to do a custom grind to suit my combo.
Have sent them all my engine/turbo specs/power goals, and they will get back to me with a recomendation, but sounds like it will be reverse split.
will post up what they come up with.
Okay here is what kelfords come up with, not quite what i was expecting !!
They were given engine and turbo specs, power goals and the breif that i still wanted good street manners
in227/ex229 .598 .598 110cl / 120cl & 115 LSA.
Okay got the cam in 227/229 .598 .598 110atdc 120 btdc
A little disappointed in idle, you know its not stock but no lope to it at all.
Drivability is great, like stock manners.
Picked up 40 rwhp over my other cam and makes peak torque 400 rpm sooner at same boost, so on the whole a worthwhile exersize
Me ?
Pump gas plus meth running two jets.
Aiming for 700 rwhp , currently 622rwhp on 15 psi but turbo exhaust housing .96AR is holding me back at present, have a 1.32AR on order.
Now thats bad news for me because I have the same .96AR, I was hoping for more like 750 + RWHP. I guess its all in the combo. I've heard people say with a 76mm & .96 they made 800 RWHP. I tuned one with a 88mm that made 670RWHP on pump then again I tuned another with a 76mm, .96 AR that only made 560 RWHP. Had a way big nasty sounding NA cam. and a necked down tubing to the throttle body..I guess I will see..I better make more than the supercharger setup which was 648 RWHP on pump and 722 RWHP on the fast gas...
#32
I don't know how the TC turbine wheel compares to the GTS. The GTS wheel is directly from the GT42, I believe.
#34
