LS1 edit ?'s ditching the maf and using a 2bar
Old Nov 25, 2003 | 10:41 AM
QuickSilver2002's Avatar
Originally Posted by y2khawk
The curve on the plastic MAF's is slightly shallower, IE hits the max frequency at a lower flow. The metal MAF's will get to the 512 limit before 12kHz.
a decent guesstimate using the coversion from g/s to lb/min and the 10 HP/lb/min generalization at peak power
100 g/s = 130 FLYWHEEL HP
That's assuming an unmolested MAF, it's been VERY accurate for me.
So in theory, you should be able to accurately fuel up to 660 or so FWHP.
Thanks for the info, I was also guessing 550RWHP.
So where do you get these metal MAFs you are referring to? Are they from older ls1s or aftermarket.
PSJ, are there any links on the net about the TCI solution. I sent an email to Mack to see what he has on it.
Old Nov 25, 2003 | 11:13 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I forget the link to TCI's website, it was not that great.
Old Nov 25, 2003 | 11:34 AM
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by XLR8NSS
Is LS1edit all that's needed with your box to run two MAFs?
Old Nov 25, 2003 | 12:17 PM
ChrisB's Avatar
Yep, with harlan's box all you would need is ls1edit and 2 maf's.
Old Nov 26, 2003 | 12:03 AM
Old Nov 26, 2003 | 02:12 AM
ChrisB's Avatar
The metal MAF's are just normal MAF's (as opposed to the 6.0l/Z06 variants). The "metal" refers to the MAF ends, not the electronic portions.
Old Dec 17, 2003 | 08:15 AM
BoazG's Avatar
ECU reads frequency readings from the MAF and not 0.0 to 5.0 volts (like in the Mustang) ?
Old Dec 17, 2003 | 09:06 PM
XLR8NSS's Avatar
Adkoonerstrator
Exactly
