lets see those merge pipe pics
Old Sep 1, 2009 | 03:21 PM
veee8's Avatar
Here is mine....
Old Sep 1, 2009 | 05:56 PM
Tally TransAm's Avatar
pretty shitty having to follow veee8 but heres mine
Old Sep 1, 2009 | 06:04 PM
veee8's Avatar
Sorry... here is another car I am working on, with a truck manifold kit.
Old Sep 1, 2009 | 06:16 PM
Phil99vette's Avatar
7 Second Club
Chris,
Did you do all the fab work on that car? Looks pretty tough!
Old Sep 1, 2009 | 11:16 PM
Ls2R1Rx7's Avatar
This will be the kit i will be going by. Very clean!!
Old Sep 2, 2009 | 10:54 AM
brandon1566's Avatar
What kind of paint is that?
Old Sep 2, 2009 | 12:34 PM
99Z28LS1's Avatar
It doesn't look like the inside is coated... but it looks like that thing was never welded
Old Sep 2, 2009 | 12:42 PM
uh . . .
its 1800 degree shitty high temp in a can paint. I was planning on ceramic coating it but the local coating place decided to hike the price by 50% from the time i called to the time i showed up and kinda pissed me off
i know its not going to hold up, and i knows its going to flake off rather quickly, but this is an uber budget build and im running outta funds so you gotta do what you gotta do. i purposefully made it so very little has to be removed to get the crossover out the bottom (1 cold side pipe and unclamp the down pipe). i just found out today that a local place has a killer deal on DEI heat wrap so i will probably wrap it in the very near future, but what little money i have left is going to finishing it. details will trickle in down the line
edit:
btw, i cant take credit for the welding. i did the cutting and measuring and fitting and everything then brought it to a friend to have it welded. if fact the only portions of the welds you can still see are the remnants of my ugly tack welds that held it together
Old Sep 2, 2009 | 09:39 PM
I dont know how much diff the heat wrap on ebay is than others, I bought 20ft for 7$ I figured id give it a try for that price.
Old Sep 3, 2009 | 06:27 AM
nastychevelle's Avatar
couldnt you just use a FlowMaster merge?
Old Sep 3, 2009 | 02:46 PM
1BAD_LS1's Avatar
Restricted User
Nice Pipes guys! Gonna try to make time to work on my merge pipe this weekend!
Old Sep 4, 2009 | 08:44 AM
  #32
Hi Volume's Avatar
id like to see some pics to see how everyones doing them. I was doing my turbo kit today, when I got to the merge pipe i just couldnt figure out how to get 2, 3" pipes to fit a t3 flange.
wait whaaaa t3???
i mean no hatin, but last time i spoke "T3" was with my 67mm turbo civic...!!!
on the reals tho, youl want 2&1/4 off each header runnin to your turbo with a legit 2-1 goin into the t3 flange. If you have a legit t3 flanged hotside turbo that ****** is gonna spool damn near off idle.
Old Sep 4, 2009 | 09:50 AM
  #33
Originally Posted by Hi Volume
wait whaaaa t3???
Im using the turbo everyone said to use on the hybrid section, theres alot of people running these supposidly with good results. i wish i woulda bought the s475 but i guess thats a later date
Old Sep 4, 2009 | 10:00 PM
  #34
Reject's Avatar
thats.....gonna be interesting to put it politely.
but heheheh all these merge pipe ****!!
Old Sep 5, 2009 | 01:26 AM
  #35
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That food coloring trick is pretty nice. I am going to have to remember that when it comes time to make mine.
Old Sep 5, 2009 | 09:49 PM
  #36
code4's Avatar
uh . . .
I used VHT a couple of years ago on my pipes. I cooked it on there according to the instructions then wrapped them with the cheapest header wrap I could find. I took it apart the other day to do some work & the paint looked flawless. I probably have around 20k miles on this set up.
Old Sep 18, 2009 | 09:57 PM
  #37
TX RED's Avatar
Just started on mine. what do you guys think?
Old Sep 20, 2009 | 04:29 PM
  #38
devilssled's Avatar
sweet **** guys
Old Sep 22, 2009 | 02:09 PM
  #39
black98ws6ta's Avatar
Recent car I did. Not the best work but it was a budget deal.
Old Sep 22, 2009 | 02:47 PM
  #40
TX RED's Avatar
damn black that looks good, I should have done mine in ss too
